Those of you without speed vibrations come inside please
my buddy and I both are having speed vibes at around 55+mph and we for the life of us cant figure it out. Anyone not have any vibes? Anyones sun visors not shake? Can you guys see out of your sideview and rearview mirrors? If so please share your suspension and drivetrain setup. Thanks!
Tires with uneven treadwear, out of balance wheel/tires, worn bushings/ball joints/tie rod ends, bent rims, bad alignment, improper tire inflation can all cause vibes at speed. Things that you can check yourself are tirewear, inflation, and tie rods. Get the front up on jackstands with the tires straight forward. Grab one of the front tires at 3 and 9 o'clock. Push with one hand, pull with the other hand. If you get any play, you may have worn tie rods. Remove/replace and get an alignment immediately.
^^^^^Good Info^^^^^
If all that checks out, check driveshaft balance.. I have had multiple f-bodies with out of balance driveshafts. Quite inexpensive fix if it is out though.
I see you have an aftermarket torque arm. Is your pinion angle set correctly? Mine wasn't and was causing a dreadful vibration. I have since had it set correctly, and I am now vibration free.
Actually, that was a lie. That only helped it. New ball joints, tie rods, and an alignment fixed the small vibrations I had at 80+ and now the car is completely solid.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
My tires are basically new ~5000 miles
My wheels were just re mounted and roadforced balanced
I have not checked my ball joints and tie rod ends, but i definitely will, however its more of a driveline vibration (i feel it through my seats on my butt lol)
Again my wheels were just balanced and I witnessed it first hand on the balancer they are not bent.
The car hasnt been aligned since ive owned it and who knows if the previous owner aligned it...gotta check that out.
And my tire pressures are all good
I am definitely going to check for tie rod play though thanks for your post! If you have anymore input I am all ears!
Actually, that was a lie. That only helped it. New ball joints, tie rods, and an alignment fixed the small vibrations I had at 80+ and now the car is completely solid.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
And again its definitely a driveline vibration, would changing my ball joints and tie rods help that? Its more behind me...if that makes any sense.
Thanks for the input fellas, keep it coming!
I just re-checked my pinion angle, I used the maddog method (put the angle finder on the torque arm and bring it to -2 and call it a day)
My shocks are stock decarbons with about 45k on them, but my buddy has bilsteins with around 10 k on them
I spent 2 years chasing a damn driveline vibration with my dana 60, and the way that mounts in the car didn't line up like the 10 bolt did. I called a speed shop that was local to me in MN and they asked me all the mods, and they said bingo it is your pinion angle. I told them how I set it and that I read it on the interweb and they laughed at me. I guess they hear that all the time, and it is the wrong way to do it. I set my pinion -1 degree from the engine crank, and BOOM driveline vibration GONE! two years it took me to figure this out. UGH. but I finally fixed it. Trust me, set it this way and if it was your pinion angle, that vibration will be gone.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
i've been having a strange sound from my driveline also. i suspect the driveshaft, and as you said, might as well replace u-joints while at it.
its almost a thumping sound at various points of the rpm range at WOT.
otherwise no vibrations at all!
however my sunvisor does swing back when i romp the throttle though! and swings forward again on the brakes hahaha need velcro or something...
You are saying having the TA still attached to the tailshaft is causing vibrations? I have a UMI xmember for the TA that i have been putting off installing because I figured it would just transmit all the vibrations right under my *** instead of disappating them throughout the tranny.....Maybe I will install it and see....at this point I will try anything. Thanks for the input
silversrtman you could run the car at speeds with it on jack stands (have the rear up by the axle) and look for anything bent or out of round.
