Bad Wheelhop Problem
Will BMR tubular lower control arms eliminate my terrible wheel-hop problem?
Also, will I be able to tell a big or little difference installing the BMR panhard rod, BMR LCA's, and BMR tubular SFC's on a T-top Camaro?
Thanks,
BMR boxed LCAs, Edelbrock Torque Arm, poly rear sway bar bushings/endlinks, poly trans mount. Those things really helped plant the car's rear to the ground and eliminated most all the flex in the drivetrain.
