Wheel alignment on a lowered car for better handling
I lowered my car maybe half a year ago with strano springs (love them!) and have yet to do an alignment since then. I just went half with a friend on the alignment tool needed for our cars and planning on doing an alignment one of these days soon in the shop.
Is there anything I should change compared to the stock specifications due to it being lowered 1.2", and is there any changes I can make to improve handling? I am not so concerned with tire wear now that the Z isn't my daily driver anymore (sometimes hydro-locking can be a good thing lol). Would love to see Sam chime in on this but I'll listen to anyone else with more knowledge on this subject than I. We're currently studying alignment angles and such, but I'm still learning. If it makes any difference, my tires are 275/40/17 front and 295/35/18 rear.
Thanks a bunch for the quick replies, I found this thread the most helpful:
https://ls1tech.com/forums/suspensio...ent-specs.html
Looks like I will be going with these specs:
Camber: -1.3-5* (depends on how far I can get it)
Caster: +4.5
Toe: 1/32" of toe out
I'll post back after I do it with before/after specs and let you guys know how it drives.
Caster: +4.5
From what I understand a slight amount of toe out would make it handle better and will want to turn into turns fast, but anything more than 1/16" would make it unstable at high speeds in a straight line. Slight amount of toe in will give you better stability at higher speeds and won't want to wander as much but will be harder to steer.
