2000 ws6 ride hight problem on one side
Hi does any ones car sit lower on the passenger side and if so how did you fix the problem to get it level also can someone explain as to why?
thank you..
thank you..
Many moons ago I heard that chevy did this so that when you sit in the car that the car sits level... Other wise known as the Chevy lean... Google it, its no joke...
LS1Tech Premium Sponsor
I'm dealing with this same probelm with a customer now. He has our lowering springs and the passenger side is sitting lower than the driver's side. Then, once we were given the measurements, we determined that the driver's side is actually sitting too high and the rest of the springs are sitting where they should. So now we're back to the drawing board trying to figure this out.
Are you running factory springs or aftermarket?
- Kevin
- Kevin
