subframe connectors
Old Dec 16, 2012 | 08:30 PM
  #41
bayer-z28's Avatar
^ Yay! $1200 for Koni DA's!!
UMI Tubular SFC's, $159.. But I do NOT discount the importance of good shocks though! ...... Do NOT.
Old Dec 16, 2012 | 08:31 PM
  #42
01ssreda4's Avatar
Originally Posted by Amazin1
if you are drag racing, subs are essential...anyone who says different has no idea what they are talking about. just like you said...the drivers side lifts up and twists the car...
Originally Posted by Grr
If you say they do nothing, you obviously havent seen creased 1/4 panels that result from flex, which never happens on a car with SFC's
This. And anyone who tries to prove otherwise, great shocks or not, jack your car up and watch the doors, hood, hatch, and t-tops not shut. That's proof enough these cars can benefit from connectors. Period. Just installed a set of MCs and strut tower bar on a 94 vert and the owner said it was like a whole different car. And, anyone who says these chassis don't flex like the wind is just showing your inexperience in working on them.
Old Dec 16, 2012 | 08:36 PM
  #43
senicalj4579's Avatar
lol
Or, $159 sfc
then, $1200 for konis because the sfc were not good enough.
so $1359 yes!
Old Dec 16, 2012 | 08:39 PM
  #44
Hell yea everytime I jack my car I see it flex. Still dont have issues with doors or anything though. I think just the fact that SFCs will stop car flex when jacking is good enough reason to get them.
Old Dec 16, 2012 | 08:41 PM
  #45
bayer-z28's Avatar
^ But the Strut bar has arguable "gains" besides being a place to rest rags or your hands while working under the hood.
Originally Posted by senicalj4579
lol
Or, $159 sfc
so $1359 yes!
Plus $250 for Strano springs..
$1609....
May we add some LCA's to that tab, Mr Bond?
Old Dec 16, 2012 | 08:42 PM
  #46
01ssreda4's Avatar
Square tube connectors are a dream for people who use floor jacks and jack stands regularly. And, even with connectors the bodies still flex some. It's crazy how flimsy these cars are.
Old Dec 16, 2012 | 08:46 PM
  #47
bayer-z28's Avatar
^ yeah exactly! Can jack the car up by the LCA mounting point and the front end comes up (with SFC's)... It's pretty funny the first couple times you see it.
My buddy has the SLP Three points and it's humorous to just stick the jack under there and play pit crew... "CLEAR!! ..... Slam...."
Old Dec 16, 2012 | 09:14 PM
  #48
SparkyJJO's Avatar
I'm used to the flex of the car, so when I first got my Trailblazer (full framed truck) and jacked it up the whole side lifted and I was like WTH lol
Now i jack up the Camaro and go WTH why does it flex so much!
MWC SFCs are on the 2013 "to-do" list. Along with a bajillion other items (like good shocks). My wallet is already screaming bloody murder at me
Old Dec 17, 2012 | 12:49 AM
  #49
JDECO's Avatar
I put them on a t-top car and it was night and day difference. Then did it again on a hardtop and didnt really notice anything.
Old Dec 17, 2012 | 09:49 AM
  #50
1lejohn's Avatar
Originally Posted by ZForce1
If anyone autocrosses it would be nice if they were to chime in here. Most of the discussion has pertained to drag racing. Every test drive/review of a car I have ever read mentions the cars structural rigidity in how the car handles - they don't like body flex when you are taking a hard turn. Above someone mentioned subframe connectors being dead weight with an autocross car. I'd have to disagree. I believe improved structural rigidity would be a good thing in either case.
The forces generated in Auto x generally aren't as much as in street driving or drag racing.
Old Dec 17, 2012 | 10:31 AM
  #51
SuperSport01's Avatar
UMI, BMR, MWC, are all great subframe connectors. Even if you get bolt in ones... weld them in. MWC are weld-in only and are my #1 choice.
Old Dec 17, 2012 | 12:19 PM
  #52
Mr. Trick's Avatar
I have 2pt UMI tubular bolt ins, I got them cause I noticed my car started getting torque dimples on the quarter panels, nothing too too big but I didnt want it getting worse since the car got painted less than a year ago. I did notice my car felt a little stiffer and my rod ended lca's dont make as much noise.
Old Dec 17, 2012 | 12:41 PM
  #53
1lejohn's Avatar
The guys that run in NASA's CMC use SFC's for two reasons to make weight for there class and add structural rigididty. Why just add weight bars when you can do it with SFC's. They are mounted low and close to the CG of the car.
Old Dec 17, 2012 | 01:03 PM
  #54
metalmilitia606's Avatar
Real world observation right here, call me a noob or whatever, but I put UMI 2 points on my stock car three years ago and it was incredible how much better the car felt. I didn't put my other suspension mods on until last year. IMO the SFC's were worth every penny.
Old Dec 17, 2012 | 01:30 PM
  #55
ragtopz28's Avatar
No SFC on a vert with sticky tires = cracked windshield for me
After insurance replaced windshield, I put on BMR weld-ins w/ no problems to date....It's a nobrainer IMOA
Old Dec 18, 2012 | 04:56 PM
  #56
lilpb1's Avatar
how much should/would it cost to get some SFC welded in? I got quoted 225 which i though was outrageous!!!
Old Dec 18, 2012 | 06:33 PM
  #57
ssvert99's Avatar
LS1Tech Premium Sponsor
MWC TRUE subframe connectors are a simple install. We usually charge 100.00 labor to do the install but sometimes less depending on what all the car is getting done.
Old Dec 18, 2012 | 06:51 PM
  #58
JD_AMG's Avatar
Go check out the threads I posted earlier, here are some posts:
Auto-xers/road racers:
https://ls1tech.com/forums/6709425-post5.html
*Note Sam's Camaro has multiple national SCCA chamionships on it with no chassis stiffening, although the class now allows it...
https://ls1tech.com/forums/6712303-post13.html
https://ls1tech.com/forums/6711313-post11.html
https://ls1tech.com/forums/6717153-post24.html
i don't have to justify crap to you or anyone else. how i spend my money is my business. and in my opinion the subs helped out my car immensely.
Wow... No need for the butt hurt, if you like them thats great...
You can't be serious....
Ive had my car (with no SFC's at the time) teetering between two wheels with the jack on one corner of the car and all the doors opened/closed fine, T-tops came off/on fine and hood/hatch opened/closed fine. These cars flex no where NEAR that. Its pretty much been proven that a STB does nothing as well...
Old Dec 18, 2012 | 10:46 PM
  #59
VinR1's Avatar
Paid a muffler shop $40 to weld my MWC SFCs on - took 20min
Old Dec 19, 2012 | 12:18 AM
  #60
01ssreda4's Avatar
I'm dead serious, and I didn't just start working on these cars yesterday. Wanna talk about flex kind sir, think your car is made of super steel? Lets try a simple test if you're so inclined. Jack both side of the front of the car up and locate two 6 ton jackstands under the front subframe (rear tires still on the ground) near the tow hook section. Remove one front tire. Put a floor jack under that lower balljoint (suspension is fully extended) and tell me how many pumps it takes for that coil spring to START to compress. It should start compressing on the very first stroke of upward pressure by you're rationale. Do that, and tell us what you find out. You might be surprised to find out what you learn when you actually get your hands dirty instead of believing forum BS.
