What could cause my car to sit higher on driver's side???
So I just got done doing a lot of mods to the car and after all is said and done, I've measured the ride height and it's off. The driver's side sits half an inch both front and back higher than the passenger side.
LF: 26 1/2 RF: 26
LR: 27 RR: 26 1/2
Here is a list of my suspension mods:
Koni SA Front and Rear with the front set on lower perch.
BMR 1.25 Lowering springs with HH mod in rear.
UMI Double Adjustable Rear lower control arms with relocation brackets.
UMI Double Adjustable Panhard Bar.
UMI Adjustable Torque Arm.
UMI Torque Arm Relocation Bracket.
UMI Front 35mm Sway bar.
UMI Rear 22mm Swy bar.
All the parts have the rod ends on them also. I have a set of UMI 3 point bolt in subframes I am wanting to weld in but I don't want to if for some reason the chassis is twisted. I haven't bolted them in either. Any thoughts or ideas? Thanks in advance.
LF: 26 1/2 RF: 26
LR: 27 RR: 26 1/2
