What should i get now ?
I just lowered my car with the eibach pro kit and my rear end is not centered any more , what should i get an adjustable panhard bar and lower control arms are will the non adjustable ones recenter it , i found on founders there lca relocating brackets and lower control arms also the panhard bar reloacting bracket and pan hard bar do i need all that ?
If you have the extra cash, yea. You will defiantly notice a difference with them. My car just squats and takes off in a straight line now. Use to get wheels hop and kick sides ways real bad 😡😡
yea its not 100% nice out yet so ill have to save up the $400 bucks for eveything i need at founders , also have to figure out this front end noise too , goin to replace the upper ball joints , add that little rubber piece thats missing and that black plastic thing see if that helps
I found the phb reloacting bracket , on car adjustable bolt phb , adjustable lower control arms , lca reloacting bracket , and i think the strut brace bar plus shipping was like $395 ...cant beat that with a stick ! !
I just asked cause the pan hard relocation is for t/d over the axle, just more clearance for you. I don't have t/d's, and was gonna get it, but read that is hurts ride quality or something along that, maybe someone else can chime in and set me straight?
The best thing you can do for your ride right now is getting better shocks, and ideally better springs.
Also, all you need to center the rear end side to side is an adjustable PHB. You don't need anything else you listed.
