UMI Performance Suspension Over Haul - 1999 SS - Lots of pics!
Old 03-25-2016, 11:03 AM
  #301
UMI Performance's Avatar
Here's a few pictures with the new Forgestar's and Rival S's on the car. The car is also sitting on our coming soon UMI coilover kit.
Old 03-25-2016, 11:06 AM
  #302
Reaper-Z's Avatar
Looks killer!
Old 03-25-2016, 12:12 PM
  #303
michakaveli's Avatar
Looks awesome! #pewterlove
@ UMI Performance
Where can we download hi-res images for our desktop wallpapers?
Old 03-25-2016, 05:51 PM
  #304
dailydriver's Avatar
N-I-C-E!!!
The ONLY thing I don't like about it are those Borla tips poking down under the rear bumper.
Old 03-25-2016, 08:35 PM
  #305
WS6 #3392's Avatar
Very nice!
Old 03-26-2016, 08:17 AM
  #306
smitty2919's Avatar
Originally Posted by dailydriver
N-I-C-E!!!
I agree... look much better doing hidden turndowns under the trunk.
Old 03-27-2016, 03:43 PM
  #307
YES!!!
Old 03-27-2016, 07:49 PM
  #308
Chris Paveglio's Avatar
Too bad the forgestars don't come in 17s because I still run 17x11 tire/wheel combo. I like how they look.
Old 03-28-2016, 07:15 AM
  #309
@ UMI Performance
If you PM me your e-mail address I can e-mail you Hi-res images.
Thanks!
Old 04-01-2016, 07:59 AM
  #310
Reaper-Z's Avatar
Any thoughts on how much this coilover kit will cost? What comes with it etc.
Old 04-01-2016, 09:31 AM
  #311
Update:
We have great news on the coilovers we have been developing with Sam from Strano Parts. Wednesday the UMI crew returned from its last test secession with great news, the shocks have passed the Strano test! After 4 to 5 different revisions, a lot of miles and modifications Strano and UMI together have established what we feel is one awesome set up with a pretty great price. Sam is very picky about how his shocks should work so it took a lot of time to develop a shock that works for him, but together we have done it. Taking Sam's knowledge and driving skills and applying it with UMI that can build about anything... well we made a pretty great team.
Here's a little info on what we will be offering. Right now the shock will be a single adjustable in rebound, monotube, the range is high with 42 adjustments but of course the range isn't all usable depending on what spring rate you run. The shock itself is an aluminum body coilover shock mounted to the car using spherical bearings on both ends, this means no rubber or poly bushing slop. The front shock bolts in using UMI brackets and eliminates the upper rubber shock mount, more rubber gone, less deflection. Both front and rear shocks are bolt in using brackets designed and built by UMI. All 4 shocks are coilover and use 2.5" standard springs, this makes ride height adjustments easy, corner weights and easy spring rate changes. Also the shock is USA built!
With in the next 1-2 days we will have a final price. I will post a realistic idea though. The entire kit which would include all 4 shocks, all 4 springs, thrust bearings for each shock, spanner wrench to adjust height, hardware and all the brackets needed to mount them will be in the $1,799-$1,849 range. Unless something unexpected pops up that is close.
Old 04-01-2016, 10:06 AM
  #312
Z28boy2000's Avatar
Hey Ryan,
Do you sell that mount for the bearing style afco's?
"The AFCO front coil overs for the 4th gen use a bearing mount on top and bottom and a standard 2-1/2" spring. They eliminate the front upper rubber shock shock mount."
Old 04-01-2016, 12:25 PM
  #313
LS1TECH Sponsor
Sam Strano's Avatar
The rubber upper mount disappears with this setup.
__________________
Old 04-01-2016, 12:43 PM
  #314
Originally Posted by Z28boy2000
Hey Ryan,
We can sell just that mount if needed, It's $39.99 per shock, $80 for both shocks. It's Afco # 20146... is that what you were asking?
Old 04-01-2016, 02:01 PM
  #315
blackandgold's Avatar
How do they mount up in the back?
Old 04-01-2016, 07:02 PM
  #316
Yes, I want to know as well.
IF they are a true coil over in back, and mounted up into the unibody shock recess, is there any mounting surface reinforcement supplied, or do we have to weld/bolt in our own plates for added strength, and then drill them?
Also, will you sell just the fronts alone, or the fronts with a non-coil over damper rear (valved for whichever stock sized spring rate we plan on using)??
Old 04-02-2016, 08:25 AM
  #317
ssjason232's Avatar
How about the adjustable upper a arms?
Old 04-02-2016, 11:08 PM
  #318
WarShrike's Avatar
Well it looks like I've found my last planned suspension upgrade for the bird! Almost all the best stuff on my car is hidden from view
That's a pretty reasonable price. I might have to travel to find somebody that can corner balance the car though, might have to go visit Vorshlag or somebody else in the DFW area.
Old 04-03-2016, 04:04 PM
  #319
I wonder how much more the double adjustables (and beyond), as well as any reservoir variants, will be?
Old 04-03-2016, 06:00 PM
  #320
Corvett z07's Avatar
I feel like the double adjustables will definitely hike up the price some, yet will be worth every bit of price increase vs the rebound only kit. Imma make a prediction, just because... 2100 give or take $50. Just a random guess, I just finished my math review-that's probably why I wanted to assign a number to it
Quick Reply: UMI Performance Suspension Over Haul - 1999 SS - Lots of pics!
