control arms
WHAT third bolt??? You mean the sway bar link?
Very common problem, bolt is probably rusted stuck. I had to deal with this and it was a PITA when doing bushings and BJs... Ended up having to drop the k member to torch what was left of the bolts after I cut through it with a sawzall to get the control arm out of there. It was a mess.
BTW that camber bolt is easy to get out and in... Turn wheel to the opposite side your working on and move the tie rod up out of the way and the bolt slides right in
