Koni Str.t assembly verification
Someone should make a new thread on how to put these together with all of the helpful tips and hints along the way of the install process with Koni STR.Ts for the front. There's been quite a few questions lately about how these go together, I don't know if anyone would be willing to do this but I think it wouldn't be a bad idea if there was a quick reference to go to with some good pictures
That looks about right - also agree that you need to install the spring perch and lower spring isolator (or whatever it's called) before taping on the cap. In some cases, that isolator may need to have the outer diameter ground a little bit to get it to fit into the lower spring perch.
