To low, Did I do something wrong?
I have a 1999 z28 Camaro. My friend has a 2000, same engine. He lowered his using ebay springs and replaced his shocks with stock ones from pepboys. It lowered perfect, not to lower at all.
So I did the same to mine. I got some $100 from ebay. Despite everone saying get the eibach springs because they are better, I got the ebay anyway cause my friends Camaro rides perfectly. Also got new stock shocks, New top strut tower mount (that part that has the bolts sticking out to bolt in the engine bay, and new rubber bushing for the not on top of the shock.
Ive never done this before but the installation seemed to go perfectly without any problems. But when I dropped the car on the ground this was my end result....
The back seem to lower perfectly, my friend and I have the same 19 inch C5 corvette rims. Our backs are near same height. But my front went way lower. And no, its not cause of the front lower spoiler, my wheel to fender clearance is way lower than his.
Was there something I did to had made my car lower? only thing I can think of is the nut on top of the shock, did I thread that to low or does that not even matter? Second, it this to low? The car actually drives just fine, but I just cant determine if it looks good or does it look like some teenager messing up a respectable car (no offence to teens that do hook up their cars correctly.
Last, The thought of doing this all over again with different springs probably aint happening, I will gladly pay the $500 or so bucks for a shop to do this next time. But I was considering using these coil spring adjusters instead to raise it alittle....
But do they good? Do they last? Im skeptical about quick fixes...
Everyone opinions will be seriously appreciated. Give me your thoughts guys, Thanks!!
You went with ebay no name lowering springs, you get what you pay for. I would use nothing but BMR springs on a daily driver.
With that being said did you remember use the spring isolator on the front perch?
What about getting properly sized tires in the front and ditching the rubber bands you have now will raise it some too.
https://ls1tech.com/forums/suspension-brakes/1788699-how-front-str-t-assembly-w-ss-springs-moog-everything-else-finalized-6-5-15-a.html
Ebay springs aren't even that cheap to be honest, with companies like BMR and Sam strano testing all of their parts in the real world and being actual posting members on the board, $250 is a steal for a complete set of springs
All kidding aside, you get what you pay for. And yeah, BMR and Strano's are the proven way to go.
A saying I recently learned and love.....
Never enough time and money to do it right the first time, but always enough of both to fix it afterwards. I'm paraphrasing. Good luck.
I actually have no complaints about the ride quality of the springs. Now I cannot compare since I never purchased any other type of Springs however I drove my car for a year on the stock Springs and now for about 2 weeks on these eBay Springs and they are absolutely fine. I do live in Florida so we are flat as a pancake here, so maybe that's why the Springs work so well for me however I don't bottom out and I don't feel any bouncing or any thing wrong with the ride quality of the vehicle. My only issue is why it went so low in the front and if I did anything to cause that.
https://ls1tech.com/forums/generatio...l#post19254514
And you can call em up and even talk to 'em just like real human like persons!
