Are ATS 4 piston Brembros as strong as the GEN CTS-V/GEN5 Camaro Brembros
I'm looking at the different caliper options to swap on the front of a Fbody and I'm really liking the ATS calipers if their as good as the other 4 piston Brembos. They're priced a little less than the other 4 piston Brembos and I think they're a better looking caliper. Do they work with a 14" rotor or do the base ATS cars use smaller rotors? If they use a 13" rotor then it might be a good option if you want to stay with 17's.
Here's a link to them on Summit but Amazon has the for less than $100 a caliper. I haven't been able to find anything about Fbody guys using them. Just WRX guys swapping to them.
https://m.summitracing.com/parts/ado...SuwaAvaz8P8HAQ
Okay thanks. That link does have some good info on them. I might go with a different caliper as I run C6Z wheels and would like to take advantage of being able to run larger diameter rotors.
Will larger and newer brakes help with the crappy ABS in these cars or do I just need to delete the ABS to get rid of the momentary lose of power braking when slowing from a highway speed roll?
Super Hulk Smash
That's a different issue. Sounds like you may have air trapped in the ABS module (which you can't really bleed out - have to open the ABS solenoids with a Tech 2 or do some low speed rolls with wheels in the air to engage ABS while bleeding).
However, if you delete the ABS, you can go with a proportioning valve which might be a good call with oversized front brakes. You can then dial in the bias a bit better.
The ABS units on these cars are not great though. With essentially the same brakes, a little less weight, and less tire up front, a C5 Corvette stops much shorter than an F-Body. And it's because the ABS system works better...
Don't know if this will help you but there is a seller on Ebay with new Camaro SS Brembo calipers with pads really cheap ($75.99 each), The problem is that they are only selling LH calipers, The only issue you'll have by running a left hand caliper on the right side is where the line connects to the caliper, You can run them as is or tap and thread the boss that's already there to make it a true right hand caliper. I bought two and when they arrived I ordered two more for a future build. Can't beat the price when used calipers without pads are selling for more. If the one linked are sold out look at the sellers other items he has more than one auction with the same calipers.
http://www.ebay.com/itm/232110019005...%3AMEBIDX%3AIT
Edit: Just talked to someone who knows more about brake calipers than I do and he said although the calipers look the same and should work just fine there is a difference in the size of the pistons so in effect the calipers are directional, From Brembo's site "Brembo's calipers are directional, due to the use of sequential piston sizes. The leading pistons are smaller in diameter in order to combat uneven wear of the brake pads. Upon close examination of the caliper, you will find a small arrow cast in place which denotes the direction of disc rotation.
are the 5th gen rotors a direct bolt up?
But we're talking about base model ATS Brembo's and not the CTS-V Brembo's.
Did not buy/install this setup as of yet.
Probably going to do this ATS setup over the 1st gen CTS-V setup...
Reason being:
-C7 325mm rotors will just bolt right up (5th gen Camaro 355mm rotors need hub bore increased)
-4th gen Camaro brake lines bolt right up (no adapters needed)
-Unsprung weight: 20 lb C7 325mm rotors v. 25 lb 5th gen Camaro 355mm rotors
Other comparison can be the C5/C6 brake swap with the bracket and cutting of spindles...
-Same rotor size at 325mm
-Similar cost (if not more for the C5/C6 kit)
-2 piston v. 4 piston caliper
-heat dissipation
-aesthetics ("look")
Any other feedback from users?
Reason being:
-heat dissipation
Does anyone know if the ATS brakes fit with 17” SS wheels?
https://ls1tech.com/forums/suspensio...-brakes-3.html This thread should have all the info and fitmit questions answered.
Thanks for the quick responses!! The video above pretty much answers my questions..
