poly engine mounts, are they all the same?
Old Jan 14, 2019 | 09:29 PM
Floorman279's Avatar
Default poly engine mounts, are they all the same?
i ask this because i know in the past a certain poly trans mount has raised the trans causing pinion angle issues......are any poly mounts known to raise or lower the engine at all? any that are consistently the same size as stock? im running a new rubber trans mount.
Old Jan 15, 2019 | 05:50 AM
drdave88's Avatar
I just searched this the other day on here. Seems Prothane is the way to go, and avoid Energy Suspension ones. Not that they make the engine sit any different, just premature wear/failure from the ES ones.
Old Jan 15, 2019 | 06:15 AM
appreciate the tip. if you have any links of where you seen this please post. i couldnt find anything
Old Jan 15, 2019 | 06:42 AM
drdave88's Avatar
Here's one of them. I just googled poly engine mounts and searched specifically under LS1Tech and started reading. There's some comments here and there in the solid vs poly threads too about going with prothane too.
https://ls1tech.com/forums/generatio...ted-equal.html
Old Jan 15, 2019 | 09:12 AM
Mgill's Avatar
what trans mount causes issues? Sorry to hijack the thread. I have prothane motor mounts they have be excellent.
Old Jan 15, 2019 | 10:19 AM
lees02WS6's Avatar
I went with prothane. Unless you're pulling the engine, or the k-member, you only want to do this job once, so pick the right part.
Old Jan 15, 2019 | 01:23 PM
certain poly trans mounts push the trans tail up and require trimming.
and I tried googling just under ls1tech and got limited rezults. Appreciate the post
Old Jan 16, 2019 | 06:50 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Prothane 100%. The Energy Suspension version with that plate is garbage.
Old Jan 16, 2019 | 07:29 PM
99Silver6.0's Avatar
Prothane! I didnt read many good things about the Energy parts. Like mentioned, I only wanted to do this once!!!! ONCE!!!!
Old Jan 16, 2019 | 07:52 PM
so they appear to be the exact size as a "NEW" stock rubber mount? wont raise or lower it?
Old Jan 17, 2019 | 12:24 AM
sjsingle1's Avatar
compared to a worn mount......poly will raise it some
Old Jan 17, 2019 | 06:14 AM
no i get that thats why i just wanna know if it raises it higher than stock? but it doesnt really matter i guess i will be running them anyway. thanks for the responses guys
Old Jan 17, 2019 | 04:56 PM
sjsingle1's Avatar
Higher than stock ? No.....but if the worn stockers were sagging a half inch you are gunna swear they did raise it higher than stock
Old Jan 19, 2019 | 05:22 PM
Toronto LT1's Avatar
where did you guys get your prothane mounts?
Old Jan 20, 2019 | 08:14 AM
I ended up getting mine from Summit with a bunch of other stuff.
Old Jan 24, 2019 | 10:41 AM
leadfoot4's Avatar
FWIW, I installed the ES motor mounts in my car, and as I recall, they were a nice, snug fit, in the OE clamshells. As for longevity, I can't be too specific, as I sold the car almost 4 years ago. However I did have them in place for 3-4 years, prior to the sale, and I experienced no issues with them.
Old Jan 28, 2019 | 12:57 PM
5.7stroker's Avatar
I saw I had ES in there and I changed them out for Prothane. Then I got a K member and did it all again because it's fun!
Old Mar 23, 2019 | 03:07 PM
JimMueller's Avatar
I need new engine mounts. I know I don't want solid, but what am I going to notice from the cabin by going with Prothane engine mounts over the OEM rubber version? Any additional noise, vibration, or harshness?
Old Mar 23, 2019 | 03:43 PM
HioSSilver's Avatar
The oe rubber mounts are definitely smoother. I wish someone made a firmer rubber mount. Poly pretty much sucks on everything besides sway bar stuff.
Old Mar 23, 2019 | 03:46 PM
sjsingle1's Avatar
i noticed no diff switching to poly......but i do enjoy not having the engine rock back n forth from worn rubber
but a big vote NO on poly tranny mount from me
