What exactly does a PHR do?
It would allow you to adjust where the rear axle is located and center your axle. So, I would suggest an adjustable PHB for your car.
Get one. They're relativley cheap and they work. Thier main purpose is to center the axle, like everyone else said.
Since the PHR swings in an arc (like a pendulum) there is some side to side movement as the suspension goes up and down. The longer the PHR the less the side-side movement. When you lower the car its the same as pushing down on the suspension from the PHR's point of view and will result in its "pulling" the axle toward the pass. side a bit. Exactly how much is a factor of your particular car's tolerances, the amount of drop, etc. So, yes, an adjustable PHR is a very good idea when lowering. You'll most likely be able to get away without one initially unless maybe you're using wider rear tires or wheels with less positive offset than stock or both.
IMO, I'd look elsewhere than BMR for an adjustable PHR. Their center adjustable design is
i just want to LOWER MY CAR thatz it
You'll want LCA's too. Relocation brackets are optional but reccommended.
