Having cage installed... do I need SFCs now?
My car is at the chassis shop having a wolfe racecraft weld in mild steele 6 point cage installed. The guy that owns the chassis shop told me that I probably wouldn't need subframe connectors after he finishes installing the cage. I'm REALLY REALLY worried about weight on the car and if I can get by without having to install the SFC's, it would be great. What do you guys think? The chassis guy told me that the 6 point cage being welded in will provide alot more stability against chassis flex than the SFC's will.
Thanks
Thanks
Thanks
Thanks
The combination of the 2 will add even more.
However, the SFCs can be added later with little effort.
I suggest you wait and see if you need them ...
So, what does it take to get a solid chassis in these cars?
They seemed quite stiff to begin with. And if they were 45% stiffer than 3rd Gens, that's a hell of an improvement. With SFCs the size and design of the SLPs, I *think* it feels tighter, but don't really have a base line. And am worried of the effect I once heard Mitch mention "I spend a lot of money, so it must be good". lol
But now you guys are saying that even a cage isn't enough? That SFCs will actually provide some benefit over that?
Seems like chasing the horizon. IDK, I just have a hard time beleiving that these cars, or cages themselves even, are that weak.
And it sucks because I'm terrified of chassis flex, because chassis flex = metal fatigue. And that = a used up car.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
