What are your caster/camber numbers?
I decided to finally get an alignment today since the outside of my left tire was wearing pretty bad. The initial numbers were surprising:
Camber: -0.5/-1.0
Caster: 3.6/4.2
Toe: -0.06/-0.06
Is this much positive camber normal from the factory? He said our cars didn't have a camber adjustment so I was just surprised how much positive there was. After numbers were as follows:
Camber: -0.1/-0.3
Caster: 3.0/3.7
Toe: 0.00/0.01
So I'm still stumped as to why the outside of my left front tire is wearing, because by my numbers it looks like the right side should wear more if anything. Who knows.
And on another note, my rear end is shifted a bit towards the right side of my car. How can this be adjusted? Just loosen the LCA bolts and shift it?
Camber: -0.5/-1.0
Caster: 3.6/4.2
Toe: -0.06/-0.06
Camber: -0.1/-0.3
Caster: 3.0/3.7
Toe: 0.00/0.01
Copy & Paste Moderator
Here is my current alignment:
CAMBER: -0.6* (maxed out)
CASTER: +4.4* one side and +4.6* the other side (closest they could get)
TOE IN: 1/32
(I went with more of a performance alingment)
Is your car lowered?
I think an ajustable PHB should fix it.
TOE IN: 1/32
Caster: -0.5/-1.0
Camber: 3.6/4.2
Toe: -0.06/-0.06
Camber: -0.1/-0.3
Caster: 3.0/3.7
Toe: 0.00/0.01
Caster: -0.5/-1.0
Camber: 3.6/4.2
Toe: -0.06/-0.06
Camber: -0.1/-0.3
Caster: 3.0/3.7
Toe: 0.00/0.01
But the tech saying this
Originally Posted by mitchntx
Either you got those first set of numbers backwards or you had one screwed up front end. Something had to be bent to get that much positive camber.
tells me you need to find another shop.
Another thing, is .7 between the left and right too much of a caster difference? Should they be equal or closer to equal? He told me .75 was optimal but I was confused on why you'd want different values.
I try to set up all my alignments with 0.5 degrees cross-caster. ANY car can have caster/camber/and toe adjustments made to the front, you just have to get creative sometimes. Here is my alignment on my personal car, alignment guys will tell you this is impossible on an older Chevelle/El Camino-
![](http://www.jackazzmotorsports.com/images/align.jpg)
