New LCA's rear end not centered??
I just installed some new BMR LCA's on my 99 TA. The rearend is now set about a 1/4 to 1/2 inch to the left. Has this happened to anyone else?? If so how did you fix it? Noone else notices, but of course I do. When I installed the LCA's, I did the left side first so could that have had anything to do with it?? The left side was torqued first. Any help would be appreciated.
^ Exactly. Get an adjustable panhard rod/bar. I have stock suspension/ride height, but still bought the adjustable PHR because even though I also have stock LCA's (that'll change soon), my rear end is shifted to the driver side by about 1". Now again, like you, I'm apparently the only one that notices it, but it's definitely there. Plus my car pulls to the left so I'm also gonna have alignment done before installing/adjusting the PHR.
But yes, get an adjustable PHR, and that will solve your rear end centering problem. Good luck.
I know this has been asked a thousand times, but no definative answer has ever been discovered. What Adjustable PHR should I get? I don't want to have the nuts backing off like I have heard the BMR's do. I also don't want rod ends (I don't like the noise and this car isn't enough of a track car to warrant it). Are there any ones with the nuts at the ends of the PHR, or are they all in the center??
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Dang, I just put my BMR LCA's in too, and have no money left for another mod right now.
What will happen if I race "uncentered?" Pls also detail how you measured it, thanks. BTW I just noticed you have a stock rear......right?
12 bolt here, if that matters.
Kleeborp the Moderator™
Originally Posted by 5LiterBeater
I know this has been asked a thousand times, but no definative answer has ever been discovered. What Adjustable PHR should I get? I don't want to have the nuts backing off like I have heard the BMR's do. I also don't want rod ends (I don't like the noise and this car isn't enough of a track car to warrant it). Are there any ones with the nuts at the ends of the PHR, or are they all in the center?? ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I really didn't like the design of the poly/poly, even with the offset adjustment, which is what prompted me to go towards the rod/rod. A good compromise IMO would be a G2 poly/rod panhard rod. That should make very little, if any noise. If it will make noise, it will be in a rough parking lot while you are driving around slow.
There really is nothing bad about driving it uncentered. It certainly isn't ideal, and basically your car will crab down the road, but I would highly doubt you would notice it under normal driving conditions. If you race it, who knows...it might have an impact, and it might not. Depends on how hard you push your car.
