LCA bushings
I don't Auto-X and only see the drag strip maybe once a month. Mostly just around town duty with some "energetic" cornering thrown in every once in a while. I'm looking for improved handling without too much increased noise and the rougher ride of rod ends.
I've almost decided on Hotchkis springs with either Koni or Strano revalves, but I'm going to call Sam when I get back to the states before I make that decision.
Thanks, Chris
aftermarkets look (to me) like they have different sized
bushings from stock. I have boxed stock LCAs with the
1LE bushings (which are solid vs the stock "waffle" rubber)
and these are firm without being harsh or noisy. But these
probably will not fit a lot of the aftermarket arms.
and banging.I thought I could beat the noise by going poly
and rubber.If you want to stay quiet stick with the stocker
or have it boxed
http://frrax.com/rrforum/index.php?a...f=3&t=3553&st=
