need some advice...
How did you come to that conclusion about the STB. I autocross and have tried with and without and noticed a big difference with it on. On the streets it makes a difference.
But we don't have to take his word for it. Take a close look at how the front suspension is designed. The front wheels are attached to almost the bottom end of the spindles. Most of the cornering force goes through the lower control arms and into the K-member. Very little force is absorbed into the upper control arms with that long, skinny spindle barely pushing sideways on them. Further, if you take the upper control arms off the car, you will see that they are rather small and weak, not even designed to take cornering loads.
Strut tower braces work on cars with real struts, like Mustangs and 3rd gen fbodies. For 4th owners, it's only a way to make their wallet lighter and car heavier.
Do what you want, but I'll see ya on the track, and my car's gonna be lighter!
Some Bilstein shocks will smooth out the ride. On stock springs they will give you a cadillac ride. But who want's that, right?
They will also help control the floaty body motions that the stock shocks can't control. So shocks will make the biggest changes, but don't get some cheap, crappy ones. Stick with Bilstein or the Koni SA's.Stiffer springs will up the performance level again. The car will still ride better than the original suspension, but with less nose dive and better turn in.
Next, I would have to say a bigger front bar, like a solid 35mm and a performance alignment. Adding some negative camber to the front tires will help them stick in corners.
There is a lot more involved, like ride height and other things that need to be worked out in advance. It can cost some big money, so set up a budget to make sure you can cover all the stuff you will need.
Also, stickier front tires to go with your drag radials can make a big difference in braking and cornering. But you know that, right?
