Creeking sound from rear
Hello
In my 95 Z28 I have this out of control creeking sound coming from the rear end. It happens whenever I drive around or when I make a sharp right turn.The noise sometimes goes away when I lube everything down underneath my car but then it usually comes back within a week or two and gets really loud. I never had this problem until I got in my accident and the rear of my car hopped a curb pretty hard. I had to replace the panhard bar, rotors and the left side axle shaft. If someone could give me some ideas on what my problem could be I would appreaciate it.
Thanks,
Chris
Thanks,
Chris
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Sway bar bushings will want lubrication, I have had
good luck with the moly/graphite engine assembly
lube.
Get under it and bounce / sway it and you should be
able to pinpoint the source by ear.
lube.
Jimmy knows whats going on. Thats the best way to figure out where it is coming from. Also don't forget to check your swaybar endlinks. Since it goes away and comes back, I think that it could be a bad bushing or bad lube. Just follow Jimmy's advise.
Chris i have the same problem on my 99 T/A. Everytime i pass over a speedbump, a dip, uneven pavement....makes a terrible creeping sound. I replaced the shocks thinking that would be the fix, but its still there. So you guys think its the swaybar bushings eh?
Had the same issue on my 99vert. GM said there was a TSB on the issue and the "fix" was to use teflon tape around the sway bar where the bushings rode. I just used grease. Squeaking gone.
Originally Posted by RaRe99SS
Will a spray lubricant like WD-40 work? I think i have this problem too, but i dont have the grease you recomended.. Where might i find? if WD wont work?
I just used whatever grease I had laying around in the grease gun; solved the problem perfectly. My buddy did the same on his TA. It seems like all birds go through this at some point in their lifetime.
Not to be the contrarian but I think it's not the best idea to use petroleum based lubricants on rubber bushings. Petroleum degrades rubber over time.
As mentioned, GM recommends teflon tape. I bet teflon paste or grease would work fine too.
Before reading this I addressed the creaking noise in my car by applying silicon grease to the front and rear swaybar bushings. It did the job and i know silicon will not harm the rubber. But after reading this I would go with teflon tape as per GM.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
On my '88 IROC i have the same prob but i replaced the SB busings and Endlinks with energy suspension peices and a syn. grease that i use alot and it didnt go away, could it be the stock LCA or PHR bushings?
