So.....slotted/cross drilled rotors????
Are these worth it, ws6store is running a good deal on these. Just wondering if these plus some new better pads will increase my braking performance noticeably. Plus, they do look pretty good.
chupr0kabra (chupacabra?) is right, don't get them if you're expecting a high performance braking system. Solid rotors are best for absorbing heat when applying your brakes. If you want your cars brakes to look pretty, then they're for you. The drilled/slotted rotors are more prone to develop stress cracks though... If you want a more effective braking system, upgrade to larger front rotors (C5 upgrade) and better pads.
Copy & Paste Moderator
Check out this thread on this subject:
https://ls1tech.com/forums/suspension-brakes/435436-do-i-really-need-cross-drilled-slotted-rotors.html
Sorry to interrupt. Thank you, drive through.
-Mike
Originally Posted by chupr0kabra
Chupacabra is where the name originated, but I modified it with pr0k in the middle. I'm half Mexican (father), so the chupacabra legend fascinated me growing up. Pr0k comes from an Unreal Tournament clan I used to play with. I'm not 100% sure where the name came from, but it stuck, and it's unique enough that I don't have to try very hard to think up a name that hasn't been taken when I play online.
-Mike
-Mike
So yeah, regular rotors it is...
