this does not look right at all!!
Now for the **** part..
whenever i hit a minor pothole, bump etc, its almost like there is NO shock at all..so i look under and i see what you see in the picture...are those springs supposed to be that compressed?!?!?!? it just doesnt seem right...makes me want to change my set up completely!
what do yall think??
one pic is of the set up with car off the ground and tire off..and other other is tire on, car on the ground
If the Bilsteins have a lower perch I'd try that with the stock spring and see how that works out.
yeah man...i was thinking the same dam thing....they look friggin upside down...****...for everyones info, i DID NOT install the fronts...had them taken to a shop for safety reasons....
screw that....im taking them to a real shop tomorrow...
as far as the kit goes, i bought it on ebay, it was the springs and shocks, they claimed they were matched for each other with a 1.25" drop
I really feel like chaging my entire set up anyway...if i was to completely re-do my suspension, what shoudl i go with...i like a lower front than rear...what do yall think..i was thinking QA1 coil overs for the front, but what about the rear?
Also, due to the pigtail design of the front spring, you can't put it on upside down. I recently installed a set of Hotchkiss springs and the coils that are closer together are at the bottom of the spring (as shown), they are not upside down. I suspect you simply have an issue of not enough shock for your springs/ride height. It's tough to screw up a spring install, you can't install them upside down and they either fit or they don't. Get a better picture that shows the rest of the spring on the side that's on the ground to be sure, but I don't think you have anything to worry about (except needing better shocks).
The coils that are closer together are the "soft" part of a spring, the coils that are farther apart are the "stiff" part of a spring. You've got it backwards.
You need to get a better quality shock. With the lowered ride your
asking for the shocks to perform more.
Hawk
When the car is on the ground, the coils don't sit one against the others.
The rubber bump stop must hit before the coils stack up. It's not possible to be sure from that picture though.
