brakes feel soft
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
My brakes are feeling really mushy. I have to push them to the floor to get the car to stop. If I pump them it does not seem to help, so I do not think it is a problem that would be fixed by bleeding, and it seems to have plenty of fluid. I also hear a swishing sound as well when I push the pedal.. Any ideas?
I have not tired to bleed them, since pumping the pedal did not work.. After closer inspection I saw cracks in my front rotors, so I may go ahead and change those out and throw some news pads on as well and bleed them and see how that works.
that sound you are hearing maybe air in your brake system. Bleed the complete system. Start with the right rear then the left rear then the right front and finally the left front. If that does not fix the problem then the sound maybe blowby of the piston seals in your master cylinder. Replacing the master is the only way to fix that and of course the bleeding will have to be done again. Good luck
Okay I just replaced the front rotors pads and a new Master cylinder. I bench bled the new master cylinder, and then bled the whole system once the new MC was on. The car seems to stop okay now, but I still hear that swishing noise when I push the pedal in.. It is a constant swishing noise. like pressurized air is escaping from somewhere. Any ideas where that noise is coming from? Could it be the brake booster doing it?
