Lowering my car??
springs around $200, labor -FREE do it your self!!
http://ls1howto.com/index.php?article=6
http://ls1howto.com/index.php?article=8
Ill let you know what i did
$200 for Springs
$700 for shocks
$300 for LCA, LCA relocation brackets, and adj PHR
$370 for a TA i should have gotten cause im pretty sure lowering the car threw off the pinion angle and im gettins some moderate vibration at highway speeds.
I took the front shocks and springs somewhere to have them installed, but the back is cake
$200 for Springs
$700 for shocks
$200 for Springs
$700 for shocks
$200 for Springs
$700 for shocks
If you want to do it yourself, make sure you have a set of spring compressors on hand. You shouldn't need anything for the back save jack and a ratchet.
$200 for Springs
$700 for shocks
$200 for Springs
$700 for shocks
can it be done cheaper? yes, much cheaper, but be careful, you may get what you pay for.
me it was 150 for the springs (if you look in the FS section you can find it to)and i did it myself in about 4.5 hours while i was BSin around with some buds of mine, keep in mind if you want to do it your slelf you need a spring compressor to do this thats why i did mine at where i work wich happens to be a shop there not hard aslong as you have basic common sence. worse case do the rears (there easy) take the fronts off and front spring and shock assimbley and take those to your local shop and have them swich the springs then take em home and put them back on..
-Josh
-Josh
Originally Posted by nokeman
So what are the best lowering springs...maybe I should say best for the money. I dont know a whole lot about suspension stuff...
https://ls1tech.com/forums/suspension-brakes/406330-those-who-want-see-ride-height-after-springs.html
-Josh
You might have better luck checking out the Handling and Braking section. This question has been asked and answered hundreds of times.
-Mike
-Mike
Originally Posted by Divergent Lightning
that is if you want to pay $700 for shocks. There are plenty of alternatives out there for less than half the price. Also, LCA and the panhard bars are optional. You don't need those if you just like the look of being lower to the ground. Panhard bar has no problems with lowering of the vehicle, just the changed angle of the LCA detracts from traction. If you want to lower your car and replace your shocks at the same time, you can do it for under $500 if you just get springs and shocks.
-Mike
Originally Posted by pSSycotic
700 for shocks? damn ..i paid 190 for my front AGX adjustable ones and their just fine...i coudnt see 700 for shocks unless it was a pure road course car
-Mike
I have eibach sportlines. They lower about 1 3/4'' and ride pretty well. I think it's the best compromise of looks and driveability. I have never scraped once mind you.
A vague question as this will provoke a broad range of answers like these. chupr0kabra has given good advise, and although he has Hotchkis springs he didn't recommend them (I do like their rates though), why?.... Because there is no best spring. Sure, if it's just looks and only looks you're into then just pick a spring (see sticky) and go for it. Tire size, shock valving (the most critical component IMO) and swaybar size will affect how various spring rates will perform. And your intended use for the car should be considered above all else.
