chopped front tires
LS1TECH Sponsor
shocks are most likely the problem. Can't say for sure, because I can't see the car and know who bad they are vs. the tie-rods and such. But I've not had a car yet that didn't need shocks long before the tie-rods and such.
__________________
LS1TECH Sponsor
Then I'd say your alignment was not done correctly (no matter what the specs say). Racks get out of calibration often.
__________________
i can take it back and have it realigned( lifetime alignment) the firestone i take it to is a NEW store.. the tech that does the alignment has 10 years exp.( so they say)... what if the problem still remains? should i go some where else.. or should i take it apart to check front end parts?
U cant see any detail in the PIC. Just looks like a tire, from all angles.. U can feel it.... its what i would can a saw tooth. one tread higher that the next( the next being lower) and so on..
LS1TECH Sponsor
Feathering.... usually caused by a wacky toe setting.
__________________
Maybe my site will help you understand alig.
I suggest high air also,I get 30-35 k from my tires with NO saw toothing, chk my specs
click on the emblem in middle of opening page to go 3-4 pages deep into site
just my $.02' Johnny
OK guys i got the alignment done and the problem is still there... i had the tires swaped, saw tooth on the out side up front,,, should i swap them to the rear... and see if the prob. stays??? What to do after that???
LS1TECH Sponsor
It won't suddenly go away, the tire is worn that way now. Rotating to get some fresh rubber down would help....
Was the alignment out? Did you use another rack? I hope so because the one you were originally on said it was all good, and clearly it wasn't. I doubt it's been calibrated since then.
__________________
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I think some of this may be driving style; even if toe
is sensible, if you are prone to corner hard while braking
you put a lot of force onto the outer edge of the tire,
make the tread-block want to "curl under and back"
and wear the outside leading edge preferentially. I have
a nice alignment and can still see a bit of this. Just how
bad of a problem is it, or is it in fact a problem (other
than cosmetic) at all?
If every tread-block is like that look to toe or cornering
abuse
If the tread-blocks are some high, some low,
that's "cupping" and more of an indicator of bad shocks.
Some tires like my current GS-D3s have more robust edge
blocks and can stand more; tires with smaller blocks, let
the blocks "roll over" more. Look at what happens when
drag a pencil eraser across sandpaper, with more or less
"roll force" on the rubber; you get even wear with light
pressure but edge-biased wear on the leading edge with
more force & roll-under on the rubber.
abuse
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
