picked up 60ft.
brackets added after the lowering springs,
at least you don't mention it, and going back
to stock springs puts you back to a better
LCA angle. Before you dollar down on a torque
arm, if you haven't put on relo brackets you
should try those; go with the bolt-ons and
you can resell them if you find them ineffective.
But this is the piece that's meant to give you
traction improvement by forcing the wheels to
plant and the body to rise, instead of the other
way around.
The torque arm's effect on pinion angle is
more a reliability and U-joint bind/scrub
issue than an instant center modifier.
At stock ride height you shouldn't need any
torque arm adjustment, at least not $300-$500
worth <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
