REVIEW: Strano Bilsteins+Hotchkis
I got the revalved shocked and springs installed yesterday and drove around for a while. (I had 2" cut springs on deCarbons) LOL
WOW sick sick sick.
Somehow, the car now stays more level on the corners AND is softer over the bumps.
The 4 tires stay planted much much better on hard corners.
They fixed a problem I was having where the car pulled on uneven surfaces.
Car used to start getting scary at 120mph. Went 130 without realizing it last night and all was smooth. (save the lectures - Autobahn)
Ride height is perfect. I have to drive over a lot of speedbumps every day. The ride height is perfectly low but not too low like I had before.
Much better traction under power in a straight like and in the corners.
I did months of research before going with the combo and I narrowed it down to Strano revalved bilsteins + hotchkis OR konis with X spring. If you haven't upgraded, this should be your next mod. My car feels like a $10k nicer/better vehicle now.
I was thinking I would probably need sway bars after the shocks but after driving around a little, I think it's perfect the way it is so I don't want to change anything (for now )
It's worth noting that when you order revalves from Strano, they take about a month to get revalved and then shipped to you. I'm suprised I never saw that info in all the posts I read. Other than that, Strano was great. If you have the choice, deal with Arlyn, she's much more helpful and friendly than the other guy who answers the order line (not Sam).
WOW sick sick sick.
Restricted User
awesome to hear, yeah my stock decarbons have been through every extreme spring setup possible from stock to eibach sportlines then to hotchkis and back and forth yada yada..lol this WILL be my next mod(i already have the hotchkis in now i gotta get the shocks in the near future), my friend has a 2000 WS6 19,000miles (stock bilstein+hotchkis) and it rides awwwesome at speed, over bumps, everything...like u said the car will feel like a million bucks glad to hear u got wut u paid for
I'd estimate about 1 to 1.5" it's nice and level front to rear with the spring pads in the rear. If you have an aftermarket y or TD's, you don't want to go any lower than this.
Good review. I have the stock shocks (eek) and Eibach pro-kit ONLY in the front. As stated before, with LT's and ORY, the pro-kit in the rear was too low for a DD so I put the stock springs in the rear again. I plan on doing the Koni's + Hotchkis from Sam once I get some money. My plan is to address issues where GM has failed- i.e. suspension, braking, etc.
Good luck with the setup
Andy
Andy
Originally Posted by z_speedfreak
so how much of a drop with the hotchkis springs you used? and has strano released his custom springs yet?
Jon
I just replaced my stock deCarbons with a set of revalves from Strano. Running the eibach pro-kit. You hit the nail on the head. It's a great feeling going around corners and having all 4 stay planted now.
