CTS-V brakes, something different
Old 09-03-2008 | 06:40 PM
  #361
Tavarez's Avatar
so would these be a good option on a c6 vette? Any new details, a cheaper great stopping brake kit would be awesome hopefully with some decent weight rotors.
Old 09-03-2008 | 11:01 PM
  #362
JasonWW's Avatar
Originally Posted by clainhart3
So, I just found out that the new camaro has the exact same brakes as the CTS-V with the same rotors just 5 bolt hats. I have it on good word that the rotors will fit on the 4th gen. Hopefully this will help you guys out.
It doesn't really help as the issue is the caliper to spindle distance. The 14" rotor is a bolt on, but a 13" needs a caliper with shorter mounting lugs.
Old 09-04-2008 | 06:42 AM
  #363
clainhart3's Avatar
Umm the SS rotors are 14". They are 14" up front and 14.4" in the rear.
Old 09-04-2008 | 07:30 AM
  #364
JasonWW's Avatar
I didn't know that, but it doesn't change anything. We already have a cheap 14" bolt on kit. What we don't have is a kit for the guys with smallish 17" rims. That's what we need and we're not going to get it with these Brembo calipers and the F-body spindles.
Since I doubt there is another spindle choice out there, we're going to have to find a cheap caliper with shorter mounting lugs. End of story.
Old 09-04-2008 | 08:59 AM
  #365
clainhart3's Avatar
oooh gotcha. Well I guess that is just another option for the 18in and above wheel guys.
Old 09-04-2008 | 09:39 AM
  #366
JasonWW's Avatar
We don't know that yet. Is this rotor going to be cheaper than the 14" vette? Same offset or different? Drilled or solid?
Now if the offset is the same, but it's a solid design and sells for under $90, then I would buy them over the vette rotors simply because I'm not into drilled rotors or spending excess money.
I'm sure someone will post up some specs once they get them.
Are you guys sure the calipers are exactly the same? Obviously they can't say CTS-V on them. So if these are powdercoated a nicer color than silver, then that would be a reason to choose them.
Old 09-04-2008 | 09:46 AM
  #367
clainhart3's Avatar
I am sure that they are the same. They will be silver also. I do not know the exact specs right now or the cost. However, the 320-v calipers are $80 for the fronts and $74 for the rear from GMpartsdirect. I would imagine that the Camaro ones would be similar.
It is a solid rotor but I don’t know what the offset is like. I will try and find out though today.
Old 09-04-2008 | 10:52 AM
  #368
JasonWW's Avatar
What calipers are those?
If you mean the CTS-V, you want the loaded ones which include the clips, pads and so forth. I think they are about $150 each.
Old 09-04-2008 | 11:41 AM
  #369
clainhart3's Avatar
Sorry I meant 320-V rotors not calipers.
BTW 320-V = 1st gen CTS-V. 320 is the chassis code.
Old 09-04-2008 | 12:25 PM
  #370
JasonWW's Avatar
OK, I gotcha.
Are there any threads on the new camaro (G8) brakes yet?
Old 09-04-2008 | 05:45 PM
  #371
some_punk's Avatar
I have found someone locally that can make custom brake hoses for me, so how much longer does it need to be for use with cts-v calipers and c6 z06 rotors?
Old 09-09-2008 | 08:46 AM
  #372
No Juice's Avatar
So I think I might be able to fit the CTS-V caliper/C6 Z06 rotor combo with my Ruff Racing 18" wheels. I may need to run a small spacer. So we need to have about 1" clearance from spoke to stock caliper correct?
Is there a stock replacement rear rotor to match the looks of the C6 Z06 rotor?
Old 09-09-2008 | 09:22 AM
  #373
JasonWW's Avatar
Yes.
On the rear, do you mean looks as in size or drilled pattern?
Not that I know of on size, unless a vette rotor will work.
On the hole pattern, you can probably find a similar looking rotor for the rear if you look around. There may even be some places that will drill them to your design.
Old 09-09-2008 | 11:25 AM
  #374
98redM6's Avatar
Good luck fitting those CTS-V Calipers. I've read that Ruff wheels can barely fit stock calipers.
Old 09-09-2008 | 07:20 PM
  #375
No Juice's Avatar
Don't know where you heard that but I have more room with these than I did with my stock WS6 wheels.
Old 09-09-2008 | 09:11 PM
  #376
mbraun's Avatar
In post 289 someone said the BMW rotor is a perfect fit with exception of thickness being 36mm. The poster stated that 32mm is max. If that is the case has anyone considered just merely turning the rotors? A local parts store can turn them down for about 10 bucks a piece. I know that this I am just starting in this thread and don't mean to offend if i am stating something that has already been discussed.
Old 09-09-2008 | 10:49 PM
  #377
fast377's Avatar
That was me. Turning 4mm off a rotor gets you into dangerous territory. I would get a pad made with 4mm less compound on them before I took that much off a rotor.
Old 09-09-2008 | 10:51 PM
  #378
JasonWW's Avatar
Yes, it's already been discussed. Keep reading, you'll see it's too dangerous.
2mm on each side is about what's designed to wear off. A 36mm rotor machined down to 32mm is ready for the trash can.
Old 09-10-2008 | 09:29 PM
  #379
some_punk's Avatar
so any luck on finding steel braided brake hoses without having to get a custom set made?
Old 09-20-2008 | 03:47 AM
  #380
jmdale1984's Avatar
I've read through the whole 38 pages of this thread, and maybe I missed it, but...
Does the 14" C6Z06 rotor and CTS-V Caliper fit on a 4th gen w/18" C6Z06 wheels with no other modifications?
Quick Reply: CTS-V brakes, something different
