Has anyone ever cut Hotchkis springs?
Yep, do the rubber hose mod. Remove the rubber isolator and slip a rubber hose over the top coil that comes in contact with the body. Results are about 1/2" to 3/4" drop.
Moderator
Surprising that the rear is too high for you; it was too low
for me after Hotchkiss all around, I jacked it up a notch with
air shocks but eventually went back to stock + heater hose in
the rear, Hotchkiss in the front. The ride quality improved
some, and less hard bang on compression (I think the Hotchkiss
might have been getting into coil bind).
