What's the best flat washer?
Old 07-13-2009, 12:36 PM
  #281
ThoR294's Avatar
www.kalecoauto.com
they dont have any wtf
Old 07-13-2009, 12:39 PM
  #282
JamRWS6's Avatar
Originally Posted by ThoR294
www.kalecoauto.com
I'd be pissed!
Old 07-23-2009, 11:39 PM
  #283
KILLER-LS1's Avatar
DID YOU KNOW ARP MAKES WASHERS!?!?!?!?!?!?! haha they are literally the best flat washer. with a tensile strength of 200,000 PSI!
Old 07-23-2009, 11:48 PM
  #284
goldmecham's Avatar
i was looking at some flat washers the other day thinking i could use them to make my lugnuts sit flush against the face of the wheel for less turbulence around the wheel allowing me to go faster on the track. i also melted the rubber out of my rear control arm bushings and just put a stack of flat washers in there for more grip off the line.
Old 07-24-2009, 08:11 AM
  #285
JamRWS6's Avatar
I just installed some large flat washers around my pistons instead of those stupid piston rings. Instant 20HP gain!
Old 07-28-2009, 01:57 PM
  #286
paytonjump's Avatar
285 posts....this is rediculous...lol
Old 09-20-2009, 07:04 PM
  #287
Nova_LS1_Swap's Avatar
all Aluminum washers are adjustable
Old 09-20-2009, 09:34 PM
  #288
Kleeborp the Moderator™
MeentSS02's Avatar
Quick question: I found some CTS-V washers on Ebay super cheap. Will they work on my Camaro?
Old 09-21-2009, 03:32 AM
  #289
greendrazil's Avatar
There are the washers that double as motor mount for imports as well.
Old 01-04-2010, 07:21 PM
  #290
Z28M6TT's Avatar
hahahaha totally forgot about this thread, and after reading that post i had to bring up ttt.
Old 01-04-2010, 09:15 PM
  #291
ThoR294's Avatar
LOL
Old 01-04-2010, 09:45 PM
  #292
MeentSS02's Avatar
I hope you guys didn't buy those like I did - I ended up needing to use extra washers just to be able to run those washers. Yeah. Washers so I could run CTS-V washers. ****'s lame.
Old 01-06-2010, 10:43 PM
  #293
99bluefirebird's Avatar
I just got done swapping all the washers on my car for ARP ones. Took about 3 days and $800 but I think it will be worth it. Never know when you might need that extra tensile strength. I also retorqued all the bolts with the proper lube. I read over on the honda forums that the ARP bolt lubricant is actually just about the same formulation as KY jelly. Luckily I already had some of that around so I saved the $7
Old 01-27-2010, 10:48 AM
  #294
usafcrewchief01's Avatar
holy ****. I need to upgrade my washers.... I figure if stickers in the ricer world are worth 5hp each then washers must be at least 10hp each. FYI: It is also rumored that Chuck Norris is made out of recycled washers, but only the best kinds.
Old 02-16-2010, 09:42 PM
  #295
SincalT/A's Avatar
What I heard was Chuck used to round house kick the center out of every flat washer at ARP till OHSA stepped in and deemed him too dangerous for that task.Stating too many injuries resulted of the centers flying out of control and striking employees down.
Old 03-12-2010, 02:17 AM
  #296
ChevyAllTheWay's Avatar
holy crap what the hell is wrong with you guys? The best washers that ive dealt with are made out of paper because of the capacitance properties that they have duh.
Old 03-31-2010, 11:34 PM
  #297
1961ba427's Avatar
And I thought I was almost through with "Bolt-Ons"!!!!!!!!!!!!!!! Now I gotta replace all my washers too.
Old 04-15-2010, 12:07 AM
  #298
silverbandit0996's Avatar
i like washers that are "energy star" approved. Maytag's pretty nice.
Old 04-15-2010, 04:12 AM
  #299
Duffster's Avatar
I apologize for not reading the whole thread, but I've heard there were some kevlar/carbon composite washers, but has ARP done anything with theirs to reduce the friction when torquing? The kevlar/carbons have been keeping the torque setting, but again, high friction and even some were warping. W/the ARPs, do you use lube? Is it counter productive to use threadlock blue? If you can use blue, is red alright?
Old 04-15-2010, 04:43 AM
  #300
98PurpleT/A's Avatar
this thread won't die
Quick Reply: What's the best flat washer?
