how can i make my ws6 hook?
TQ arm will be the biggest improvement,I run a BMR non adjustable and it's a 100% better than stock,Lc arms will be a needed change too,
Basicly start change rear end comopents out.
Don't be too mad, that means you are puttin down some serious POWAH, in a way, you should be glad!
Torque arm, Lower Control Arm with brackets, and pahhard bar will make a difference,
so will a moser rear end, with mickey thompson's and a dump clutch at 5k!
I think having a good street tire and good shocks helps tons. Now if ur tires are cold or the road is 15 degress and you just romp on it yea your going to spin off the road or if your on crappy payment.
I had a chassis-mounted one though, do not recommend it for daily driver. It drove me ******* nuts, always banging the car, and brought SO much noise into the cabin.
Check this list out. It may help answer some of your questions. Bob
http://www.exoticperformanceplus.com....html?item=540 This may help. Bob
