lowering springs = poor ride?
i drove a buddies lowered TA the other day and the ride quality was awfual. i am not sure of the kit he had but wanted to know if this is a comman thing.
i could fell every little bump on the road.
thats what i was thinking but wasn't sure. is that because the shocks are compressed more because of the springs and have less movement?
Damping quality... The DeCarbons can barely dampen the stock springs, with lowering springs having higher rates do to their less travel, the stock deCarbons will just make you bounce like a box spring.
Kleeborp the Moderator™
LS1TECH Sponsor
A messed up spring can really screw you up, but not as much as using any spring (good or not) with shocks that cannot control them. That's my guess with your friend's car, and it's also likely he used some crap springs too.
__________________
Yeah, that was my experience too. Tried several different after market lowering spring sets and they all rode like crap. Then I had my stock springs cut with stock shocks and got the stance I was looking for with a smooth ride too.
LS1TECH Sponsor
Fella's..... note that these two guys are both on their stock shocks. Lowering springs worked not well for them, and when they returned to stock springs (even if cut a little), things got much better (though I'd say far from good knowing the stock shocks' abilities).
Amazing what happens when a shock valving better matches a spring rate. And in this case it's still not a great match.
The point is to those wanting lowering springs, but NOT willing to look at upgrading the shocks. It's a bad idea. Shocks are spring dampers. When the spring damper doesn't jive properly with the spring rate, you won't like the result. And that is the biggest reasons folks don't like the ride of lowering springs. It's not because the springs are "so stiff", it's because the springs and the shocks don't match. A well matched set will actually ride quite well. Firm? Absolutely. Harsh? Not if things are well matched.
__________________
