Alignment specs, best all round usage to use?
Old Apr 8, 2007 | 04:10 PM
SilverSmoke's Avatar
Default Alignment specs, best all round usage to use?
On LS1 there used to be a post about the best setup for all round use on a F-Body. Supposedly the stock settings from GM were sub-par for us racers and spirited driver.
I would use my car both at the autox and 1/4" if I ever get there. Otherwise spirited driving on turns and straight ways.
any recommendations on what specs to follow?
Thanks for any direction.
Old Apr 8, 2007 | 04:33 PM
VIP1's Avatar
Copy & Paste Moderator
This is what I have now (others run pretty close to it too)
Caster: +4.5* (aim for up to 5*)
Camber: -.7* (aim for up to -1*)
Toe: 0
Thats the closest I could get on my car. Every car is different though. If you want to improve straight line tracking, go with some TOE-IN (1/32).
If you want to go further, you can go more negative in the CAMBER and more positive in the CASTER. Some people are running -1.2* to -1.5* CAMBER and +5.0* to +5.5* CASTER. Thats a bit much for the street and harder to achieve with stock/unmodified parts (and will cause tire wear). Maybe those with more aggressive setups will chime in with their specific setups. TOE IN will improve high speed stability (the car will run straiter and wander less). TOE OUT will improve corner entry ease , but at the expense of high speed stability (the car may wander more).
Here are some more threads on alignment:
https://ls1tech.com/forums/suspension-brakes/636138-alignment-specs.html
https://ls1tech.com/forums/suspension-brakes/544067-best-way-nimbleness-f-body.html
https://ls1tech.com/forums/suspension-brakes/534685-front-end-alignment-questions.html
https://ls1tech.com/forums/showpost....1&postcount=25
https://ls1tech.com/forums/suspension-brakes/460439-there-such-thing-performance-alignment.html
https://ls1tech.com/forums/suspension-brakes/242549-what-your-caster-camber-numbers.html
https://ls1tech.com/forums/suspension-brakes/193740-went-tog-et-alignment-today-not-happy.html
Old Apr 9, 2007 | 08:57 AM
Toe: 0
https://ls1tech.com/forums/showthread.php?t=636138
https://ls1tech.com/forums/showthread.php?t=544067
https://ls1tech.com/forums/showthread.php?t=534685
https://ls1tech.com/forums/showthread.php?t=460439
https://ls1tech.com/forums/showthread.php?t=242549
https://ls1tech.com/forums/showthread.php?t=193740
Great! Thank you so much!
yeah, I'm looking for a nice balance of straight line at high speed (NJ roads suck and high speed driving and a wondering car on bumpy wavy roads is freaky in itself, lol!) and good turn in. Don't want to kill my tires either on wear patterns and such. My wheels cannot be rotated front to back
Old Apr 9, 2007 | 02:00 PM
VIP1's Avatar
You're Welcome.
Old Apr 9, 2007 | 08:11 PM
gollum's Avatar
Heres some good suspension specs: http://www.angelfire.com/my/fastcar/suspension.html
Old Apr 11, 2007 | 12:51 PM
You're Welcome.
I don't see this in any sticky, or tutorial. Should add this as good reference
Old Apr 11, 2007 | 01:14 PM
hpjunky98's Avatar
Im running -1.1* Camber on both sides, with 0* toe and 4.3* Caster... works for me on the street.
