Thumping noise during hard acceleration, what else should I check?
I'm getting a thumping noise under hard acceleration, sounds like its coming from the rear of the car, only in 1st gear. I just changed the tranny mount today, didnt make a difference, torque arm mount looks good, everything seems tight. Only thing I can find odd is that theres a mark on the axle where the intermediate pipe is hitting it under acceleration. I checked the bumpstops and there not cracked but they look a little wore, then again, I'm not sure how there supposed to look. Only other place I can see the exhaust touching is the driver-side collector is touch the heat shield. Car has the Eibach Pro-kit with Edelbrock shocks, anything else I can check out? Thanks in advance.
pat
'00 NBM SS A4
Pacesetter Headers, ORY, Lid, Eibach Pro-kit
pat
'00 NBM SS A4
when I bought mine it did that, tunred out that the borla cat-back was bumping the floor under hard acceleration. I loosed up the exhaust pipe clamps, repositioned the offending pipe so it was further away from the floor. It never hits now.
Originally Posted by jimmyblue
If it's following wheel speed check that the I-pipe isn't
interfering with the driveshaft balance weight or yoke;
they can run pretty close.
pat
the drivers side lifts up and something hits the floorpan it seems, make sure you have decent clearance where the header is at near the floorpan as well as the y-pipe. sounds like your stock engine mounts have alot of play and things are moving too much. check those out.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
My old 2000 Z28 did that as well. Turned out to be the Y Pipe from the headers. When the engine torqued over under hard excelleration the y pipe would slam under the driverside floor pan, drove me nuts. On another note look to see if your spare tire is loose
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Originally Posted by gun5l1ng3r
What is happening if I get a large thump only when accelerating over bumps (bigger bumps)? Maybe the axle hitting the rear hump?
Could be the torque arm hitting the tunnel (if the rearend and torque arm are aftermarket), could be the exhaust hitting the upper panhard bar...could be any number of things.
-Mike
