View Poll Results: Which lowering springs?
Eibach Pro-Kit
17
26.56%
Hotchkis
34
53.13%
Other (tell me what)
13
20.31%
Voters: 64. You may not vote on this poll
Hotchkis or Eibach Pro-kit???
Old May 30, 2007 | 06:34 PM
02trns_am's Avatar
Default Hotchkis or Eibach Pro-kit???
I know there are alot of threads about lowering springs and I have read most of them but I still can't decide on what springs to get. Whatever I get I'm going to buy thru Strano. I know Sam's springs are suppose to be really good but I really don't want to wait on them. Is there any way that the pro-kit won't sag in the rear? I really don't know to much about Hotchkis. Thanks for the help guys.
Old May 30, 2007 | 10:22 PM
02TransAm/Batmobile's Avatar
I am not trying to be an ***, honestly. But I would do some more searching before posting. What is it that you are looking for in lowering springs? Eibach's are way lower than Hotchkis'. Not to mention that Eibach's are crap.
Old May 30, 2007 | 10:40 PM
02trns_am's Avatar
Thats what I meant when I said "I know there are a bunch of threads about this and I have read most of them" I've read thru threads for 2 days now about lowering springs. The one thing I keep coming up with is Strano springs are the best but if I can't get them for a while that don't help. I'm looking for something that will have a smooth ride and handle exceptional while also having a nice stance. Sorry, I know this topic has been beat to death.
Old May 30, 2007 | 10:43 PM
Blakbird24's Avatar
Restricted User
Given the choice between Eibach and Hotchkis, it's an easy, obvious pick. However, Hotchkis are progressive springs, Eibachs are linear, so it's almost an apples/oranges comparison.
I will say I love my hotchkis springs...factory ride, exceptional handling.
Old May 30, 2007 | 11:10 PM
jimmyblue's Avatar
Moderator
Between the two I'm glad I picked the Hotchkiss,
they're nuisance-low at -1" and Eibach would be
worse (other than the SLP Eibach which, used,
would be another and inexpensive option for about
a 3/4" drop).
Old May 30, 2007 | 11:25 PM
02trns_am's Avatar
linear and progressive? now I'm lost. Are there springs that would be better than the Hotchkis?
Old May 31, 2007 | 12:20 AM
BobDoLe's Avatar
i'm not too impressed with my eibach pro-kit springs. the rear drop was unbearable until i removed the bumpstop spacer - still hits the bumpstops hard sometimes. the front drop is nice, but after 3k miles, the front tires started rubbing the top of the plastic wheel wells during HARD cornering. my 32mm solid sway bar "upgrade" surprisingly flattened out the front, so maybe that will help... but i have acquired stock rear springs that i intend to put in to give the car a nice rake and save my back.
Old May 31, 2007 | 07:25 AM
mark.deady's Avatar
i have had both and Hotchkis is the best ride but the elbach have the lowest drop, and the ride is choppy the hotchkis are smooth alot like factory... i vote hotchkis... good luck... mark
Old May 31, 2007 | 11:11 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Well I guess your problem has vanished since the Strano Springs are in!
Old May 31, 2007 | 11:26 AM
Redlinez's Avatar
I don't know who told anyone Prokits are linear, but the Pro means progressive. Most aren't happy with Prokits, particularly the rear springs. I voted Hotchkis as I'll probably end up with those or Stranos.
Old May 31, 2007 | 11:34 AM
Sam Strano's Avatar
LS1TECH Sponsor
Where'd you get that idea? Does that mean you need Sportlines to be sporty? LS1 Pro-kit fronts are linear rate 400's. It's a name, that's all.
And Urban Legend mentioned it--I have mine back in stock (as of today).
__________________
Old May 31, 2007 | 11:49 AM
02trns_am's Avatar
Sam, Will you have some of your springs in stock like a week from now or are you going to run out pretty fast? Thanks. Hopefully I can get my hands on a set of those.
Old May 31, 2007 | 12:05 PM
Sam Strano's Avatar
LS1TECH Sponsor
Hard to say.... I have about 1/3rd of the order sold already (and most are packed). I find it hard to believe I'll sell the rest that fast.... You "didn't want to wait" in your first post, and that would be best just to make sure.
__________________
Old May 31, 2007 | 09:03 PM
02trns_am's Avatar
Well I ordered the Strano springs.
Old May 31, 2007 | 09:27 PM
stockerws6's Avatar
I am probably getting Hotchkis springs but I noticed a lot of people on here say they lower the car more than the advertised 1". Did they lower your car more than 1"?
Old May 31, 2007 | 09:30 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
My prokit is fine..although the rear is a tad lower than the front....Friend has Hotchkiss and I cannot even tell he is lowered.
Old May 31, 2007 | 10:18 PM
02trns_am's Avatar
I'll let you guys know what I think about the Strano springs when I get them installed. I'm sure it will be the same as everybody.
Old May 31, 2007 | 11:28 PM
Blakbird24's Avatar
Restricted User
Yeah it's definetly more than 1". For the appearance part it depends on what you are looking for. The Hotchkis springs give the ideal "OE" look...meaning they give you a stance that puts your tires perfectly in the wheel wells. The gap is even all the way around, unlike our stock gap which is grand canyon-like at the top. Something like the Eibach setup will give you a VERY lowered look, where the gap at the top of the wheels is significantly less than the gap on the sides of the wheels. Keep in mind this also affects performance, because the lower you go with the car, the less suspension travel you have. I wanted simply to make my car look like a sports car instead of an off-road vehicle, while limiting suspension travel as little as possible.
Old Jun 1, 2007 | 09:29 AM
02trns_am's Avatar
Thanks for the info blakbird. Well said.
Old Jun 1, 2007 | 09:53 AM
jimmyblue's Avatar
Moderator
I got exactly -1" off the Hotchkiss, I measured before & after.
However -1" all around made it look like it was dragging ***.
I went back to stock springs minus the donut out back and
it has a better looking stance and a somewhat more cushy
ride over bumps. Kept the H fronts.
