Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird Why is Brake Light On<br>Guide to diagnose trouble and recommended solutions.
Abs Inop, Brake Light, Trac Off
#261
Very interested in that info as well. My ABS light has been on since the shell swap was done it it still functioned. However, the last two events I have done the AND has failed on the last runs of the day. The first time it cost me $430 in failed contingency and it likely will again. NEED this fixed
#262
i'm having the same issue, abs inop, brake, and tcs off, lights on. Codes c0550 = ecu malfunction probable cause; failed ebcm (tcs)
& c0896 out of range voltage at the ebtcm probable causes; charging system fault, open or short circuit condition, poor electrical connection, failed relay condition, ignition switch fault.
I'm the original owner and i'm at 137,000 miles. I have had the above codes come on and off for a couple of months, and have since replaced the front wheel hub assembly's that included wheel sensors, replaced alternator, and "just" cleaned the rear sensors for the first time, one had a strand of wire stuck to it (wire not in photo below).
Cleared codes, i'll have to drive it for about a week and see if codes come back, hopefully it was just the dirty rear sensors.
Abs trouble code search
http://www.wellsve.com/custom_search...45&submit.y=18
2000 f-body dtc's
http://www.gearchatter.com/viewforum36.php
2000 f-body dtc's
12/31/2012
06/25/2017 Still good with no issues at 191,726 miles.
