Rear Passenger Rotor Keeps Warping. WHY??
I've been through 3 rotors on this one wheel in less than one year, and that's considering I drive on the warped rotors for months.
I've run both the stockers and wholesale direct drilled and slotted rotors, and all have been fine except for the ones I put on the rear passenger tire.
What could be causing this to happen?
A caliper piston that sticks or a hose with a torn liner that forms a one way valve and holds the brake fluid under pressure even when you're not using the brakes and driving along. Replace the hose and caliper, they're cheap enough and you'll be done with it. Either resurface the rotor or get a new one at the same time.
Vernon
Vernon
^^^I don't believe so
As far as the original problem I'd tend to think the caliper was sticking slightly, thus creating extra heat and the warping you are describing. It's the only logical cause I can think of.
I can see a warped axle overheating disk brakes but a bent wheel that's still useable shouldn't. The caliper follows the travel of a bent axle being rubbed back and forth instead of floating over it.
Vernon
Hmmm...
I know I had a bent wheel on that hub, and I thought I had a bad axle.
Based on pictures of the axle, everyone here said it wasn't bent, so I just replaced a
bearing.
I guess its the caliper then...
bearing.
I don't know how you can tell that from pictures. I would drive the wheels in the air and see if the axle is bent. If it appears bent, mark it at the highest spot, then rotate the wheel about half-way around and check it again. If the high spot stays the same it's the wheel, if it moves it's the axle.
Vernon
Vernon
I was thinking of a way to see if the axle is slightly bent, it will make everything bolted onto it wobble, like the wheel and brake rotor. But the brake caliper is attached to the axle housing so it stays still. Then when the brake wobbles in the stationary caliper it creates constant friction and would cause overheating and continually warped rotors. If you think you may have bent that axle there's no way to tell without checking runout, either on the flange with a dial indicator or with the wheel spinning in air like I said.
Vernon
Vernon
First remove the wheel. Then get a large screwdriver and find a spot on the rotor that you can grab. You need to pry the piston inwards to see if it is sticking. If the piston moves than you should check your slides. Remove your caliper bolts and try to move your slides back and forth. Most likely they are sticking but if they move with your hand then your brake line might be clogged. Doubtful.
