metal noise
Noise is coming from front passenger side, only when I hit bumps. Sounds like metal on metal. Shocks are less than 1 year old, new sway bar and bushings installed in December. I can't recreate the noise while the car is sitting still, I bounced the car up and down as much as possible and nothing. Any idea's.
I sprayed all the bushings with lithium grease and the noise is still there. It sounds like a coin in a can. I can bounce the hell out of the car sitting still and nothing. So, I'm assuming it's not a up and down movement. What else could it be? I'm tempted to take the shock off and see if it's coming from the top where the bolt sets on the strut mount.
That would be a good description, a jingle. It'll be 2 weeks until I can tear it apart and look for it, anniversary this weekend and lasik eye surgery next. I'll update if I find anything.
LS1Tech Premium Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
the rear bushing on the lower a-arm looks to be in bad shape. Are these press in bushings? I don't know if this is the noise or not, but my squiller(sp) on my brakes is make noise every now and then, I'll check everyhing this weekend.
Front end is rebuilt. Found noise, when I replaced the swaybars one of the old washers on the swaybar bushing fell into my lower control arm. Oh well, it needed to be rebuilt anyway.
