View Poll Results: Should I delete my ABS
Definately do it!
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
31
49.21%
Fix the ABS problem dummy.
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
32
50.79%
Voters: 63. You may not vote on this poll
ABS delete...yes or no
For those of you who have removed ABS what are you going to do when you need to slam the brakes and turn... this is where I find ABS to be a benefit. In the staights you can prob save a few feet by removing ABS but when you really need to avoid a situation and put the brakes to the test and TURN you will wish you hadent removed the ABS...
Plus who cares about 15lbs.... Just run a few gallons less gas or get on an agressive diet...
Im not going to remove my ABS but hey thats me
Is your car 3 or 4 channel ABS? Do you rely on traction control as well? I feel it is in a similar category regarding aiding in your driving ability. Earlier 4th generation ABS systems were worse then newer. 3 channel ABS is rather poor and doesn't really address well what you're considered.
I've addressed some of the benefits above...weight savings was only one of them. Once again modifying the car with performance enhancements aren't
for everyone...some rather leave their car stock which is perfectly fine.
have some pictures of the installed kit? i made my custom line lock set up if you remember (https://ls1tech.com/forums/drag-racing-tech/759365-line-lock-question.html) and was wondering what would work for me.
I would like to see some installed pics also. The more I think about this, the more I want to do it. Especially since I'm looking in to putting CTS-V calipers all the way around.
It would be interesting to see the how an insurance company might react if you were in an accident and the claims adjuster noticed "hhhmmmm did this guy do away with his ABS?".....could they deny coverage based on that? That argument could be made for every non stock part on the car, I realize this. But I know I get small discounts for airbags, ABS etc. etc.? Curiousity, that's all
To answer the post, I would first make sure the brakes are 100%. Then decide to remove the ABS. I wouldn't remove the ABS in fear it might cover another underlying problem. Another thing so consider is the with the adjustable valve, unless its in the passenger compartment, you will likely adjust it once and never touch it ever again. I can't see very many people swapping the skinnies, tuning the brake proportioning, going for a blast getting out, tweaking some more, another blast, getting out tuning some more.......then going back the other way when the DD wheels go back on. You could probably count turns or make marks or something, but unless its at your finger tips it probably won't happen.
I have C5 brakes up front, 3 channel 12-bolt out back no traction control and the only time my abs light came on was at the track, usually at the end of a couple runs in quick succession. I don't think I have ever felt the abs, even when auto crossing.
The stock brakes will function as normal. Actually, you'll have the ability for more control regarding brake bias due to an inline adjustable proportioning valve unlike the stock setup which relied on the ABS modulator.
Reject, you've made a one-off install. Give me a call if you would like to discuss your particular situation further. I may be able to help.
Here's one of our kits installed on an F-body.
![](http://img.photobucket.com/albums/v650/LowETz/100_0817.jpg)
To answer the post, I would first make sure the brakes are 100%. Then decide to remove the ABS. I wouldn't remove the ABS in fear it might cover another underlying problem. ..... I don't think I have ever felt the abs, even when auto crossing.
If you've never felt ABS, you've never used it and you'd never miss it. Regarding insurance companies...my feeling is if you're being picked apart regarding removing ABS, you're going to get hit with the same problem that you've completly altered your braking system using non OEM components which are not approved for your car.
#33
does this delete kit mess with the tcs system at all and if i do have tcs is that a 4 ch i'll be looking into one of these come spring i hate abs and have never had it go off in my TA only in my winter beater on ice
#34
Brakes should feel no different then they felt at stock. You do have the ability to improve brake performance with the adjustable proportioning valve as you'll have control to biasing the front/rear brakes with the kit.
TCS will be deactivated...something most do not like either. If you have TCS, removing it as well will take a total of ~20lbs out of the engine bay and further clean up clutter. If your car has TCS or had TCS, then you need to choose the 4 channel setup upon checkout.
#35
yea i'm not a fan of the tcs system either i keep forgeting to turn it off when i go to the track nothing looks worse then popping hte clutch at the track for a burn out and it doens't move
#37
That's my problem...my brakes feel like ****. I'm assuming it's because the abs is acting up. It keeps saying the rear sensor isn't working...but I've changed it.
#38
It's too hard to diagnose over the internet. I'd suggest taking it either to the dealer and have it repaired if it's important for you to retain ABS...Sensors aren't too expensive, but if it's the actual modulator control unit it's going to cost you quite a bit of money to repair.
You can delete it as well. There will be one less thing you'll have to diagnose on your car.
It all comes down to how important it is to keep the ABS system on your car. I can tell suggest to you our kit will not diminish normal braking performance as you used to have.
#39
Thanks for all the info. It's not THAT important for me to keep the ABS. The more I drive it and think about it, the more I want to delete it. How does your kit install exactly? Do I cut and flare the lines that come up from the calipers and then plumb them into the prop valve?
