Dimond Vs Weld In SFCs
Are the dimond SFCs worth the extra cost? I wasn't even going to bother with choosing since I have a tunnel mounted TA, but I'm going to be swapping that out for a full length arm to gain a little ground clearence. So now I can buy the dimond SFCs, but do they really stiffen the car that much more? I'm planning on getting into some auto x and road racing so my car will be punished pretty bad, and I need some SFCs really soon.
Thanks in advance
Thanks in advance
If you are looking into making a handling car, and have stock suspension, SFC's should be way down on the list...
Do things that need to be upgraded first, like shocks, springs, and swaybars with an emphasis on the shocks first.
Yes I realize that, but I already have some new creases from my new motor setup and only have about 1500 miles on it. I'm in need of the connectors. Then I'm getting some stranos and konis a little while after the SFCs, then some strano sways, then some new wheels and tires, and the list could go on and on.
My car handles decent for now, but has alot of room for improvement. I took my brother for a ride yesturday and he couldn't believe how flat the car stayed, but that was taking corners with a suggested speed of 35 at about 65. I could go alot faster, but the roads aren't very smooth and bump steer can be kinda scary at high speeds.
I know the shocks and springs should be first on the list, but SFCs and a stronger rear are up on top right now. It will probably be another long winter here in wisconsin so I will have plenty of time for suspension mods.
Actually our 3-Point SFC's will work with all tunnel mount torque arms out there... well at least the ones I am aware of. We actually recommend this type of set-up because the torque arm bolts under the SFC's and allows the stress of the arm to be generated into the SFC's rather then the floor of the vehicle. But if you are removing the torque arm you have now that won't matter to you.
If you have any questions regarding one of our SFC's set-up's please ask and I will be glad to help.
Thank you!
Ryan
Thank you!
Ryan
Thank you!
Ryan
Thank you!
Ryan
And yes I have the stock springs and shocks
These cars are a uni body and have alot of flex.
Regardless if you do buy SFC's, buy from UMI, they are a good company.
