Anyone do Fender Rolling?...again
Old 03-04-2009, 09:54 PM
LS1Aggie09's Avatar
Default Anyone do Fender Rolling?...again
I know I asked before and never got a good response from anyone with an Eastwood or other machine to do it. I have a guy who is going to do it for me by cutting the lip and then folding it up...hell I may just do it haha. But to get it done right, I am wondering if any of y'all have suggestions or can do it?
I heard the going rate in other areas is between 40 and 60 dollars and the process doesn't take long.
-Karl
Old 03-04-2009, 10:56 PM
Sex On Wheels
will69camaro's Avatar
Karl just rent the tool and do it yourself. We did Kat's and first side took about 30-45 minutes to do then the 2nd took about 20. It's easy just take your time and make sure the paint is good and warm with the heat gun. I dont know why you wouldn't just attempt it yourself.
William
Old 03-05-2009, 07:56 AM
LS1Aggie09's Avatar
I would but i don't want to shell out the 300 bucks to rent one...and then have it break on me heh
Old 03-05-2009, 08:19 AM
Donohue96M6Z28's Avatar
Lmao, its not going to break. I know "duffster" on here just got one, Im sure he'd rent it out, but he's a couple hrs from you.
Old 03-05-2009, 09:32 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Are you the same guy that was trying to rent mine out for $40 to have a gang-bang entire car club use it? If so, what a cheap ***. I'd rather not rent mine out to someone like that.
Enjoy cutting your tire sidewalls!
Old 03-05-2009, 12:27 PM
Sex On Wheels
LOL same...
It wont break as long as you use it correctly. It does come with instructions.
William
Old 03-05-2009, 01:19 PM
LS1Aggie09's Avatar
I was going to split the 300 between everyone...that way if it broke, you would be out nothing. If it did not break, I could give you more than 40 for everyone using it...everyone being 3 cars thats more like a tower, not a gangbang
Old 03-05-2009, 01:54 PM
LS1Tech Co-Founder
Nine Ball's Avatar
It won't break if used properly. The $300 deposit is to ensure you bring it back. You aren't actually spending $300, it is just a deposit. But, no worries, I'd rather not rent it out to you and your buddies for a fender rolling party. $40 PER car.
Old 03-06-2009, 02:53 PM
$O$OE's Avatar
Where can this "fender rolling tool" be purchased at? anyone?, nine ball??? link if possible..thanks
Old 03-06-2009, 04:37 PM
stdjsw311's Avatar
WOW!
http://www.tirerack.com/accessories/detail.jsp?ID=52
i did mine on my mustang race car with a bat and it looks great! it sounds ghetto but works just fine. you can not feel a lip on my fender at all and do not cut my slicks!
Old 03-07-2009, 03:18 AM
01z
01z's Avatar
some dude used channel locks on his nova to "roll" his fenders for bigger tires. it looks like ***. i will see if i can get some pics to make fun of.
Old 03-07-2009, 06:02 AM
LS1Tech Co-Founder
Nine Ball's Avatar
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Old 03-07-2009, 12:58 PM
GreatWhiteZ28's Avatar
I used a bat on my Ranger when I bagged it, worked fine and looked fine too...havn't really looked into rolling the fenders on the Z yet, but I'm sure the Bat technique will be done agian, or just roll my rubber mallet along the inside edge, (the top of mine comes off and is cylinder shaped)
Old 03-07-2009, 01:06 PM
chupr0kabra's Avatar
Or you could just let a pit bull do it for you: http://forums.vwvortex.com/zerothread?id=3103189
-Mike
Old 03-07-2009, 02:17 PM
99_ls1_z28's Avatar
So this tool only cost $269.00???
Old 03-07-2009, 02:21 PM
Sex On Wheels
Kinda looks like what the website says...
Old 03-07-2009, 04:57 PM
ls1n00b's Avatar
When you are rolling fenders, what size tries can you fit on the rear? I have 275 in the back with no rubbing, if i roll my fenders how much can i go up in size?
Old 03-07-2009, 05:07 PM
stevensLS1's Avatar
315s and larger.
Old 03-07-2009, 05:12 PM
It's more about wheels than tires. I rolled mine because I was running 315/35/17 tires on 17x11 ZR1s. After I put them on, I went for a drive and noticed neat little "slits" in the sidewalls. The tires that came with the wheels were BFG drag radials with only a little tread left, so I replaced them, but when I put the Goodyear GSD3s on them (which are like steam rollers), I knew I didn't want them cut up, especially at over $300 per tire. So, I rented Tony's fender roller and heat gun, and rolled the lips back.
What I did was roll them back as far as I felt comfortable, then adjusted the tool to curl the leading edge back further. That way, even if the tire went to some extreme angle and hit, it would hit a curved surface, rather than an edge.
-Mike
Old 03-09-2009, 09:13 AM
stdjsw311's Avatar
i am running 305/30's and no rubbing of the fenders.
