Trouble Code PO157 / BBH02S22
Old 05-08-2009, 02:15 PM
Shackleford's Avatar
Default Trouble Code PO157 / BBH02S22
BBH02S22 circuit condition (heated oxygen sensor bank BB2 sensor 2)
BB2. - system running very rich or lean-check other BBcodes first.
Went to Autozone and had them pull the trouble codes.
I bought two good used oxygen sensors awhile back. They've been sitting in my room for awhile.
Should I just go ahead and replace the front two oxygen sensors?
Old 05-08-2009, 02:38 PM
98FreakZ's Avatar
well seeing as how the code is showing for the rear O2 sensors, replacing the fronts would have no effect.
Is your car tuned?
Old 05-08-2009, 02:39 PM
Is your car tuned?
How did you get rear sensors?
Not tuned. Mods are in sig.
Old 05-08-2009, 02:46 PM
98FreakZ's Avatar
Sensor 1 is the primarys just after the manifolds
Sensor 2 is the heated O2 sensor before the cat
Your code says sensor 2
Old 05-08-2009, 02:48 PM
Starting from the cylinder, sensor 2 is pre-cat and sensor 1 is post-cat?
When I said front, I meant pre-cat.
Old 05-08-2009, 02:51 PM
98FreakZ's Avatar
Actually the DTC codes read as follows
Bank 1 Sensor 1 - Drivers side after manifold
Bank 2 Sensor 1 - Pass. side after manifold
Bank 1 Sensor 2 - Drivers side Heated before cat
Bank 2 Sensor 2 - Pass. Side Heated before cat
Bottom line, buy some sims or have it tuned and your problem goes away
Old 05-08-2009, 02:53 PM
Why buy sims? I have working used oxygen sensors. I'm going to try to get those on this weekend. Are they hard to replace?
Old 05-08-2009, 02:55 PM
98FreakZ's Avatar
Not hard to replace. Just need a 7/8 Open end wrench and about 30 min but the codes you have dont say anything about the front O2 sensors being bad. That's why I'm telling you to just buy the sims for the rear or tune the codes out with a basic tune anyway
Old 05-08-2009, 03:00 PM
I think we're having a semantics problem here. When I say front, I'm referring to the ones closest to the block - PRE-cat, not POST-cat which is closer to the muffler.
Old 05-08-2009, 03:03 PM
98FreakZ's Avatar
that is understood but what your not understanding is that the codes your throwing are only refering to the rear O2's so why replace the fronts?
Old 05-08-2009, 03:04 PM
98FreakZ's Avatar
Anyone else wanna help out here and chime in because I'm not really getting anywhere?
Old 05-08-2009, 03:09 PM
What are you talking about? It says sensor 2, BEFORE cat or PRE-cat. I'm talking about THOSE.
Old 05-08-2009, 03:12 PM
98FreakZ's Avatar
Its pretty self explanitory - You only have two sensors on each side right?
Front and Rear!
Like I said before, Just buy sims for the rear or tune them out! Problem solved!
Old 05-09-2009, 11:59 PM
FIREHAWK #07's Avatar
shakky, its the rear o2's! get them deleted via tune.. it'll probably be cheaper to tune them out permanently than to replace them.
the front and rear o2's are different.
Old 05-10-2009, 12:12 AM
Rear as in AFTER the cat? lol.
Old 05-10-2009, 12:37 AM
yes...
Old 05-15-2009, 11:50 PM
yes...
How will tuning them out affect everything?
Old 05-16-2009, 12:02 AM
((((((Administrator))))))
CRAGER's Avatar
P0157 P0(ZERO)157:
http://www.gearchatter.com/viewtopic8597.php
DTC P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
Bank 2 = Pass Side
Sensor 2 = After Cat
........with tuning you can turn them off, or buy some simms.
~ Craig
Old 05-16-2009, 12:08 AM
Originally Posted by CRAGER
P0157 P0(ZERO)157:
Bank 2 = Pass Side
~ Craig
Will that affect economy? performance? etc.?
Old 05-16-2009, 12:10 AM
CRAGER's Avatar
No it will not. Rear is just telling the PCM the Cat is "ok." Your car runs off the front o2's.
~ Craig
Quick Reply: Trouble Code PO157 / BBH02S22
