Went to the 1/8th mile. *vids* 7.9@96 :(
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
http://www.youtube.com/watch?v=L_aJWzedYSA
http://www.youtube.com/watch?v=vwlnG5AXq0g
How close am I to 11's?
If I could get a better 60ft I'd be there. Best I could get out of the stock clutch was 2.060ft.. Nitto NT05Rs did well just clutch stuck to the floor if I launched hard. I tried slipping it and it just stayed on the floor .
Best run:
2.03 60ft
5.28 330 ft
7.94 1/8th
94.1 mph
Best MPH was 96. Still with a 2.0 60ft.
I know a 1.6 60ft would put me at least at 7.5. Driving the same.
Bummed I can't get a good 60.
Best run:
2.03 60ft
5.28 330 ft
7.94 1/8th
94.1 mph
No, a 1.6 short time would get you to around 7.2's if you trap 96mph. Cutting .1 off your 60ft is good for .15 overall ET.
Don't use the 1/8 mile to 1/4 mile conversation sheets, they are way off on my car. With that 96mph, and even a 2.0 60ft, you should run 11.80's-12.1's right now in the 122-124 area.
OK also have more than one person telling me the DA and weather is bad right now for the track. One guy ran 2 tenths faster two weeks ago.. So my 2.0 60ft would be a 7.7.
Not bad. lol
Not bad. lol
What was your DA at the times of your runs? You can plug in the numbers by going to
http://www.wunderground.com/history/
Then plugging in the numbers
http://www.dragtimes.com/da-density-...calculator.php
The DA is going to be bad in Texas for the next 4 months, no real way to get around that until the fall cool fronts start coming in.
http://www.wunderground.com/history/...tatename=Texas
There is the link for Caddo Mills tonight. How do I figure out the DA?
They are 550 feet above sea level.
Then find out the elevation of your track. Look at your slips, and plug the weather numbers in to the 2nd link that correspond with the exact time you made your passes at the track from the 1st link(scroll down the page). At the top of your slip, there should be a readout of what time your passes were made during the night.
running in the summer is not the best b/c of the horrible da we have. i usually won't go to the track unless it is below 1500.
i posted this to you on CF but not sure which site you check more. get a line lock and heat the tires up properly and do the ranger clutch fluid flush before each run. that will hopefully help your 60' and your clutch not sticking. your clutch may not like those rolling burn outs. line lock is a couple hundred bucks and the fluid flush is like $10. line lock is easy. i bought the cartek one and i was able to put it in in a matter of minutes. and i have mine on a wireless remote so i didn't have to mount a switch in the car.
Thanks for the tips Andrew. I do the Ranger clutch flush everytime I go to the track.
Also I tried slipping the clutch way to much the time it glazed. Next time i think I'll launch around 3k with a slight slip.
get a line lock. trust me. worth the couple hundred bucks. if you need help installing it i can help. check my nitrous pass video and watch my burnout. simple, good, and painless burnout. line lock ftw!
Will do. I'll take you up on the install help. The wireless setup probably looks clean.
Hope this clutch can hold up to 150 shot rolling starts for a while. Do not think I'll spray at the track till I get a better clutch.
Destroyer of Exotics
if you guys are throwing out free installs i could use some help..
lol
insomz you car is sick. i had a budy of mine go 11.1@131 with a 500hp ls3 cam only/bolt ons. so i know yours should fly also. your car is gonna be sick on the dope. let me know if you need any help with the nitrous setup i got a few tricks up my sleeve
lol
