Power Steering hoses for a 1998 Z28
All
My wife's Z28 convertible is leaking - rear pinion seal and now the PS pressure line.
I am going to do the PS lines myself but I only see a listing for the pressure line at the online stores (RockAuto, Napa, even AutoZone). They list the return line only for the 3.8 V6 and nothing for a V8. What gives - is the return line the same for both the 6 and the 8?
Once I swap them, how much fluid do I need and what is the procedure to bleed the system?
Thanks
Stacy
Thanks
Stacy
Just get some 3/8 hose at Advance Auto and cut to length
As for the power steering bleed, the way I did mine was disconnect return line and put in a bottle. Lift the front of car, then turn the steering wheel lock to lock while maintaining fluid level in reservoir til you get clean fluid coming out.
I would rather have the orginal type line especially since the metal end is crimped onto the rubber hose of the original...
When you do this - is the car running or off? disconnect the line from the reservior? what keeps the fluid from running out of the reservior?
Yep I can find the HIGH PRESSURE one at most places - RockAuto, NAPA, autozone etc. - but they only show the return line in a list for the V6
I guess I will go to the stealership....
workin on my car last night i realized im going to have to convert my PS lines to AN so i took off my PS lines, so if you will go for a used one lemme know, if i was you i would find a new one if you can
