6.0 build.
Old Jan 22, 2011 | 01:45 AM
fbody junkie's Avatar
Default 6.0 build.
i got a 00 camaro and i wanna put a 6.0 on my car.. but i dont know what to do to it all i know is i want all motor.. and keep it a 6.0
i heard that i could used an lq4 or an lq9 for 6.0 but i dont know what set up..
i already have a build 6speed tranny build by a local shop and 4.10 gears also build by them but i want a set up so i can put around 460rwhp or so...
Old Jan 22, 2011 | 05:19 AM
1c62nv's Avatar
You want a new longblock LS6?
Old Jan 22, 2011 | 07:05 AM
ZONES89RS's Avatar
In-Zane Moderator
If you can get a LS2, do that, otherwise, the iron 6.0 does not have the hole drilled for the power steering bracket provision.
Old Jan 22, 2011 | 11:11 AM
i want a 6.0 either ls2 or lq9.. but not so sure.. which one im gettin thats why im wondering what would be the best heads/cam/intake set up
Old Jan 22, 2011 | 02:26 PM
ZONES89RS's Avatar
In-Zane Moderator
A LS2 will have the 243/799 heads and then there are tons of grinds to pick from or have Pat G or someone spec a cam for you, from there, you can be happy with that or have the heads ported or buy different heads and go with whatever cam matches the heads better.
You need to research here and look at the tons of builds and see what sounds like would make you happy, i am running a stock LQ4 with a Trex cam and i love it, but a set of 243s will be in it in the near future.
Old Jan 22, 2011 | 02:38 PM
lemons12's Avatar
Lq9.. best bang for the buck and easiest swap..
If I were you I would do l92 heads and ls3 intake.. then get pat g or someone to spec you a cam.. that should be around 475, conservative. if you have a grand extra get the heads and intake portedthat wipl be good for another 40 or so..
Old Jan 22, 2011 | 02:45 PM
Ls1_axxxman's Avatar
+1 on that, Sounds like you would have similiar setup to mine..Im runnin a cam only Lq9 with 4:10's, puttin down a lil over 400 to the ground. You wont be dissapointed.
Old Jan 22, 2011 | 03:35 PM
1c62nv's Avatar
or you can go with an LS2 and do a cam only internal mod and put down a little over 500 at the wheelsjust depends on how much money you want to spend on it
Old Jan 22, 2011 | 04:13 PM
lemons12's Avatar
For the money it wouldnt be worth it to go ls2 over lq9. Same power for a whole lot more money. You also won't be making a little over 500rwhp cam only with any kind of ideal setup.
Old Jan 22, 2011 | 04:29 PM
1c62nv's Avatar
OP, Check this thread out. It has a lot of good info. It may not be the ideal set up for your wallet but it is possible.https://ls1tech.com/forums/dynamomet...s-503rwhp.html
Old Jan 22, 2011 | 04:35 PM
lemons12's Avatar
That is a WHOLE LOT of money for that... You could spend a fraction of what you are suggesting and make the same power.
I'm not going to spend an extra 2k for 10 peak rwhp.
Op of you want to spend that kind of money.. Go with an l92, more power and room to grow for the same price.
Old Jan 22, 2011 | 04:47 PM
1c62nv's Avatar
There is no more money in this build than any other build of the bolt on sort. There are no magazine "power" parts for show. Every piece made the power that it should have with this combo. Yes it came with a price but isnt that what its about? Making power? The only other options were forced induction or spray.. I wont spray anything so the cost factor between FI and NA sort of balanced out, and I didnt have to replace a hood either
Old Jan 22, 2011 | 04:51 PM
lemons12's Avatar
That is not average power for that build for obvious reasons.. If you are so naive to think that then ok, I'm not going to argue about it.
For the op, that is extra money. He is starting from scratch so has many options.. Your option would be one of the most expensive and yield about the same, or less, power.
Old Jan 22, 2011 | 04:56 PM
at the moment i got 241 port and polished.. a 224/230 cam on an ls6 the 4.10s and build tranny and im making around the 425rw neighborhood but not completly satisfied i want a little more and the set up i have right now is going to my trans am as my daily driver but i want an lq9 set up and something around the 3k neighbor just parts.
Old Jan 22, 2011 | 05:04 PM
lemons12's Avatar
What I'm doing...
Selling the heads cam intake etc that I have now.. buying an l92 pull out.. you need to buy tsps conversion kit for 400$ and the 24x box for 250 and an ls3 intake/rails for 300~.
If you have 3k cash to spend now, by the time you sell off your parts/motor you will have money left over.
For the time being I'm going to go gam only, should make around 450-65rwhp through my 4000 stalled auto.. later i will get the heads ported and either port the intake or go to a fast. Through a t56 you would be around 485.
Keep in mind you would still have a ton to grow and making good power on a very small investment.
Old Jan 22, 2011 | 06:16 PM
avengedws6's Avatar
LQ4 and boost it.
Old Jan 23, 2011 | 09:56 AM
2001AntiVenom's Avatar
I'll sell u a disassembled iron 370 that's fully forged with arp head studs. Shoot me a pm if ur interested.
Old Jan 23, 2011 | 02:32 PM
Dave_the_SS's Avatar
To be honest with everyone in this thread lala (op) has no intentions of doing any of this. The kid has everyone in San Antonio about this. We've all pretty much told him the same thing u guys are and to get on here and read .... Then read some more.
He's the kid that he'll ask u something then when u give him the answer he'll turn around tell u your wrong cause he thinks this oR someone told him that.
Not to mention he 19 with 4 f bodies??? That's cause everyone he's turned to ****. Kids a ******* retard had a hole in one of his heads and he tried patching it with jb weld....
Don't waste your time with this kid....very few 1-2 of the San Antonio guys even talk to him anymore cornets fact that he's a dumbass
Old Jan 23, 2011 | 02:54 PM
beedo's Avatar
Wow, tell us how you REALLY feel about him. Lol, I was about to detail my 6.0 build for him but you saved me lots of typing, Thanks!
Old Jan 23, 2011 | 03:19 PM
dave... dave... really? and dude.. yes im going to get this.. its my 6months project.. but just waiting for the right thing i dont wanna jump on it and you guys dont help you just make smart comments. and guys i am trying to get this just trying to make sure. and you the fat guy that no one likes.. you always making smart comments on everyone.. sorry dont wanna be rud... but let me do my search plus im still young yea im 19 but its ok i figure i still got a long way to learn and to do things so im not rushed..
