need some advice regarding an AR build/purchase and what to avoid
i'm very familiar with the weapon platform itself, but i'm not familiar with which brands are good or bad these days. i'm looking to buy/build an AR in a few months, and id rather not learn the hard way. is anything even available right now?
what i know i want:
-gas
-16-18" barrell
-M4 buttstock
EDIT: my budget is $1500 including optics. I also changed my mind on the 7.62x39 because of a lot of issues ive heard about. So I'm sticking to the tried&true .308 AR10.
https://www.gtdist.com/ProductDetail...CWVMF30816ORCE
i got my G31 from these guys, and they're great.
what i know i want:
-gas
-16-18" barrell
-M4 buttstock
look at Barnesprecision.com
Andy Is my rifle sponsor and makes amazing products, all parts except magpul furniture are made in his shop. Chances are if you go Colt, Bushmaster, or a few others you will be getting his parts anways. He's only one of 5 shops that make all the parts for an AR style rifle. Also, lifetime warranty and MADE IN AMERICA.
If you're going with a .308, you'll be looking at building an AR-10. From my experience with the AR-10 platform, parts aren't as interchangeable as its AR-15 cousin. Lower receivers can be proprietary and fit only that same brand upper receiver. Check out Armalite, DPMS, Rock River Arms.
If you want to go with a larger caliber, go with a .300 Blackout. Uses a .308 projectile in a chopped down .223/5.56 case. Uses all .223/5.56 parts except for the barrel which makes it much cheaper than building a .308/7.62. For good deals on parts hit up AIM and JSE Surplus. As far as brands, any major supplier will do. Troy, Bravo Company, Spikes, Noveske, Palmetto, etc.
The 7.62×39 ak round is good all you need is a standard ar15 lower with the correct mag andvthe upper all the parts are the same except the barrel and the bolt. The ammo is alot cheaper than 300blackout and all the others mentioned.
7.62x39 ammo is cheaper, but that is for the foreign steel-cased ammo and tends to be a great deal less consistent than American manufactured rounds, some of that **** is 1970s era soviet surplus..If you bought American 7.62X39 FMJ, it would cost a great deal more, maybe more than 300 AAC blackout...
