I have a loud squeeky door
Edit: You got it fixed - good deal .
If it is as bad as mine was, you'll need to pick up a new splined shaft + "roller wheel" from the dealer for pretty cheap. Here is how the door works: there is a spring loaded guide with two indentations (halfway open and all the way open) that roll on a wheel. The wheel is mounted parallel to the ground and is held in place by a small (maybe 2") splined shaft. My squeak turned into a "pop" everytime I opened the door.
Use a screw driver to pop the door spring out and then pick up some vixegrips and a BFH to yank the splined shaft out. That **** is tough to get out - I had to go to a body shop to get them to yank it out .
Good luck.
Ryan
Good luck.
Ryan
