What size wire do you use to weld subframe connectors?
The 3200 is going to struggle a bit, you'll want a thicker wire and flux core wouldn't hurt -- it'll get more heat into the weld than using gas. Just crank it all the way up, you'll need every last amp that little guy can produce
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by Brains
The 3200 is going to struggle a bit, you'll want a thicker wire and flux core wouldn't hurt -- it'll get more heat into the weld than using gas. Just crank it all the way up, you'll need every last amp that little guy can produce ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by Mark98SS
Been practicing with my 3200 on 1/8 angle & it just doesn't penetrate on gas.
Going back to to flux core tomorrow to see if it will do it.
edukatek12@aol.com
Try a friend with a bigger welder or a bodyshop. I don't know that I would trust many welding shops with my car. They often are not very careful. My parrents own a welding shop too. I say find a bodyshop because they have an apprecation for the car.My dad also owned a Bodyshop for 16 yrs.
