TIG welders... newer to this type of welding
So I've done basically every other type of welding... Taken classes and stuff, but never moved to tig. I decided I'm going to teach myself, similar technique to gas welding. What is a good entry level tig welder, will probably buy it new. I know theres a lot out there on the market, but something 1500 and less it looks like.
I have the econotig and the syncrowave...both pretty good machines, since you can stick-weld with both also.
Depending on what you do, the econotig should be enough for you....60%DC
I own a fabrication shop and the econotig never gets used, because the syncrowave can handle a little more.
Miller Syncrowave 180 here...
I taught myself to use it in just a few days.. TIG welding just takes practice, and lots of it. Try to find yourself some scrap exhaust or metal and practice on all types of metal.. The carbo, 409 and some 304 are pretty similar and easy to weld. Getting into 321 and aluminum gets tricky. The biggest thing you need to teach yourself is heat control. When I first started, all I wanted to do was crank the heat up and use the pedal to control it. Best thing to do is remember where a good heat range for a metal is, then set that range as your max, so when you go WOT on the pedal, you dont burn the metal.. If that made any sense..
Brandon
Dont try to do it without a pedal, learning this is all about control and coordination, mastering it is an art. I was a x-ray pipe welder for 7 years.
I have a new Miller syncrowave 200 and dont really care for the start on it. Im used to using a lincoln squarewave 355 and a miller syncro 350. But the 200 works great for home.
200 model replaced the 180.
10 Second Club + 14 Second Truck Club
i just ordered a Lincoln Precision TIG 225. i cant wait to get it. i have never TIG welded before but i have done quite a bit of arc and MIG so i think i should pick it up pretty quick.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Brandon
