Building a homemade air compressor, have ?s.
I'm almost done, but my question is, a guy I work with says I should put something on my compressor to adjust the belt tension, besides using the slots in the electric motor mount, and using myself to adjust the tension on the belts. Do I really need to do this? I've looked at alot of compressors and only one had way to adjust the tension other then slots in the mounting plate.
Thanks.
Thanks.
I could see using a tensioner with a higher horsepower setup, where you want to get maximum wrap on the pulleys along with a tight belt, so you don't get slippage.
But for a "normal" compressor (5 true horsepower or less), I wouldn't worry about it. What size motor/pump are you running?
yeah, a tensioner is not needed. The only reason they are installed on packages is for maintenance reduction and to keep a constant belt tension over time.
You need to be careful with how tight you get the belt. There are specifications for pumps and motors for the amount of side load bearings can handle. What kind of pump is it and what kind of motor? On a typical 5 hp setup, you probably only want about 8cm deflection with 5-8 lbs force IIRC.
